Today while I was removing the passenger side valve cover, which by the way was not easy that last bottom bolt was a bear. I found this hard hose was cracked on both ends, one end went into a line on the firewall that's going into the cab and the other end was going into the head. I'm not sure what that hose does, can it be for the blend door of the AC? Do you know what it is? I don't even know what to call it to order a new line.
2008 Cayenne S
Edited by valfam
Every time I find a crack/leak, often at the connection to barb like shown, or area more exposed to heat, I replace it with fuel line, flexible but hard enough not to collapse in vacuum.
