Hi all,
Having some issues with the passenger side litetronic xenon headlight on my 2001 986S. The main xenon and high beam lights stop working randomly. If I disconnect and remove the headlight assembly, then reconnect and refit it, they'll work for a period, then stop working. If I remove and refit the assembly, they'll work again, for a while. Wasn't sure if it was a ballast issue, so swapped them between the headlight assemblies and no change. I've also noticed that the sidelight starts flashing when i indicate left.
I've tried cleaning the electrical connectors to no avail. Does anyone have any idea what could be causing this? I don't want to replace the whole headlight assembly without trying other remedies first.
Many thank
Khush
Look at both the plug and socket on the car sometimes the connectors can be pushed out of the socket when inserting the headlight. There could also be damage to either due to someone pushing too hard and breaking either the socket or plug.
Thanks, that's what it was. The headlight tray was damaged and the connector wasn't being held in securely. Replaced the tray and all seems good now. Thank you
