What are the steps to replace 987.1 Boxster secondary air pump 997 605 104 00?
Is it located inside of the Passenger side air intake manifold?
Secondary Air Injection Pump (911 Boxster Cayman) - 99760510402
Edited by alex222
The valve, however, is located on the engine under the passenger side intake plenum. at a minimum you'll have to remove the two crossover tubes to access it. worst case you have to pull the whole passenger side assembly off.
Your picture is a 986.1 (with a rear Plexiglas window in the upper right corner of the picture) and a different airpump. I was asking specifically about 987.1 and my pump.
Edited by alex222
