Got the check engine light on my 24 718 GTS 4.0.  Scan error code was P0304 and it was thought to be a fuel issue.  Change of fuel did not solve so they changed spark plugs, no help.  Error wont re set.  Car is pretty new with <1600 miles.  Anyone got any ideas?
Thanks for the input.  Dealer put in new plugs and swapped coils with no change.  Saying the misfire count is very intermittent and that all coils are firing normally.  Here is what they said "tested for misfires and monitored misfire count and found a small 1-3 count and multiple cylinders.  Swapped coils and plugs for cyl 1,3,4 and found small misfire counts still present in same cylinders.  Drove vehicle and found the misfire counts are very sporadic but will not re set the fault".  Is it possible that the harness supplying power to coils could be the culprit?  Just a random thought.  Appreciate your help.
