Going to install Techart spacers, need torque info
the 15mm spacers have lug nuts not bolts, You put the lug bolts through the spacer and then it provides studs for the wheels. What I need to know since I'm buying the spacers used so I have no manual, is what should I torque the lug bolts holding the spacers on to and do I still use 130nm for the nuts that hold the wheel on.
