I posted this by accident in the GT3 group. I intended
it to be posted here. Appologies.
I am sure you are all aware of the Brey-Krause http://www.bkauto.com/porsche/r2020.php fire extinguisher
holder.
However, whilst in Europe I found out that Porsche sells its
own fire extinguisher bracket. According to the PET print out it's
on page stz2/02/8/26/826-07 and the relavant part numbers are:
996 521 674 and 996 521 607
Has anyone tried to install these parts or know how they compare
with the BK bracket above?
Will it hold any of the US fire extinguishers?
Thanks, Jan
I have the BK bracket and it's fine. It just bolts on to the bracket under the seat. I didn't remove the seat to install it, I used slightly smaller bolts than the ones supplied with the kit and was able to install it just fine with those.
The only issue with the BK is that it slightly limits the travel on the seat (mine is a power seat) in terms of how low you can push the seat and how far back the seat will go.
Thanks for the info.
Is there anyone out there that uses the OEM Porsche bracket?
Are any of our readers in Europe because they are likely
to be using that bracket instead of the BK one.
