30k Service time
My 1999 Speed Yellow Aerokit coupe needs a little tlc. The odometers reads 29,832......Time for the 30k. Correct me if I am wrong, but the 30K is only an oil and filter (pollen) change correct? I was planning on doing this myself because it is easy.
Is the 45K service the spark plug change??
I already ordered the oil wrench tool and printed the directions.
The service manual shows for up to model year 01 that you change the plugs at 30,000 miles. Make sure you use the newer style plugs 999 170 207 91 (14FGR 6KQU). Or, the latest Porsche recommends.
Porsche changed the interval on the newer cars in MY01 (to 60,000 miles) but left the older cars at 30,000.
I want your car. Been looking for a 996 that needs service. Aileen who worked on your car needs a 30k service and we are going to film it. Want to film a 996 service at the same time, with the cars side by side. Also do the brake fluid replacement with my Motive. I have done the 15, 30, 45, and 60k services and have the tools and the 'official' maintenance schedule given to the mechanics. This time you can get your hands dirty and play a leading role.
Let me know. Jeff
Tool Pants. You want my car... you got it. I can easily do this stuff on our early 911's but the 996 stuff is a little scary because of the space. I would love the help. I'll buy the plugs, oil, oil filter, alum seal, pollen filter, (i have a K&N so no air filter) Do I need anything else?
Chad, I do not think I have your email so send it to me. Aileen already bought her parts on Saturday. Aileen and I will do the Boxster and you and Loren can do the 996. Get your parts. This will be a good DVD.
I have a ball end metric allen wrench set, but it is not need. I have a snap-on wobble extension that Porsche says is needed, but I change the pulgs without it. Funny, but some of the special tool stuff the shop manual(s) say you need, the mechanics at my local dealer do not have as they use what they have that works, as they have to buy their own tools.
If you want to change the brake fluid then buy at least a liter of your favorite flavor. We will do the clutch at the same time. If your power steering fluid level is ok then you do not need to buy a can of Pentosine. I use the 99 cents per gallon washer fluid
We will time the 2 teams. But you should beat us as it takes a bit longer to access a mid-engine. Jeff
I just completed this service on my 00 996 C2 - All except the plugs - it was VERY easy and straight forward thanks to the DIY section from this board.... and I saved about $500 - plus it was fun....
Major maintenance USA up to and including model year 2001
Major maintenance after
30,000, 60,000, 90,000, 120,000 mls etc.
Diagnosis system: Read out fault memory
Polyrib belt: Check condition
Change the engine oil and oil filter
Replace the spark plugs
Vehicle underside and engine compartment: Visual inspection for leaks (oils and fluids) and abrasion (lines and hoses)
Coolant hoses: Check condition;
Radiators and air inlets at front: Visual inspection for external contamination and blockage;
Coolant: Check the level and antifreeze protection
Air cleaner: Replace the filter element
Particle filter: Replace the filter element
Fuel system: Visual inspection for damage, routing and secure fit of line connections
Power steering: Check the fluid level
Parking brake: Checking the free play of the parking brake lever
Brake system: Visual inspection of the brake pads and brake discs for wear
Brake hoses and lines: Visual inspection for damage, routing and corrosion. Checking the brake fluid level
Clutch: Check the play and pedal end position
Throttle actuation: Check smooth operation, check the full throttle position with the Tester
Steering gear: Visually inspect the bellows for damage
Track rod joints: Check the play and dust bellows
Axle joints: Check play, visual inspection of dust bellows for damage, check screw connections of running gear adjustment facility, front and rear, for secure fit
Drive shafts: Perform a visual inspection of the boots for leaks and damage
Exhaust system: Visual inspection for leaks and damage, check suspension
Tyres and spare wheel (collapsible wheel): Check the condition and the tyre pressure
Check the door, lid locks and safety hooks of the front lid to ensure that they are secure and functioning properly
Seat belts: Check function and condition
Vehicle lighting: Check function; All headlights: Check adjustment; Horn: Check operation.
Windscreen wiper/washer system, headlight washer: Check fluid level and nozzle settings, pay attention to antifreeze protection in the winter months.
Electrical equipment as well as warning and indicator lights: Check operation.
Test drive:
Remote control, front seats, foot and parking brakes (also actuation travel), engine, clutch, steering, transmission, ParkAssistent, automatic speed control, TC/PSM switch, heating, air-conditioning system and instruments: Check operation.
Oils, fluids: Visual inspection for leaks
USA Additional maintenance,
replacing spark plugs
911 Carrera (996) up to and including MY'00 (Y) every 30,000 mls
911 Carrera (996) as of MY'01 (1) every 60,000 mls or at least every 4 years
We just did one for about $100 2 weekends ago.
