Flash it to what? There is only one Porsche DME program for a MY99 Carrera.
If you mean buy an aftermarket chip - then my only advice is to choose a shop that will give you a dyno run from your own car - proving the before HP (at the rear wheels) and after HP (at the rear wheels).
Thanks Loren, the shop said that I will not get all the benefit from my intake/exaust unless I do the $1400 computer "flash". They must be talking about a chip, what kind of improvement might I see or feel?
The most realistic performance increase will probably be the weight loss associated with the reduction of your wallet by $1400. Most computer voodoo is just that unless you have *significantly* changed the intake parameters (i.e. cams, turbo, supercharger, etc.) I think the reason that Lauren suggested a before/after dyno run is because most of the time, there isn't anything gained in this area. Even where there are some gains, it is my experience that there is merely a shifting of the peak without any increase in the area under the curve and in many instances, there is actually a reduction of the area under the curve. Like I said, mostly voodoo unless you have really changed the engines flow characteristics with something more than a 'free flow' intake or exhaust. Just my two cents. :soapbox:
