P0410 Fault Code
Can you hear the air pump when you first start the car?
If not start with checking the fuse - it is a 40A fuse next to the DME (under the removable panel behind the rear seats).
Sorry for not knowing but what does it sound like / should I be listening for? If you can humm a few bars i can probably catch the tune ... :D
Update. I finally had this checked out. Apparently I need a new check valve and air pump valve. one was corrodded / blocked and one they recommened be changed at the same time ... i dont recall which was which.
Parts are about $75 each and labor is $300. Does this sound about right?? Thx, Mark
