Whistling noise 996 Carrera 4 Cabrio
Also try putting some masking tape over the gap between the front trunk lid and the bumper cover. This is a common source of whistling sounds. If the tape eliminates the whistling, you can fix the problem either by adjusting the front of the lid to sit a little lower, or by installing a rubber "bulb seal" on the lip at the front of the lid.
