Vacuum line needed
I'm installing a Co2 cooler over the intercoolers. The solenoid works on a pressure switch, designed to mount on the fuel pressure regulator line to signal acceleration. I think I can see it but it's buried. Any other lines in easy access that I can use?
Thanks Loren I didn't receive the email.
But it is vacuum that's needed. The company said the fuel pressure regulator is where they usually tap, but they have never had a unit installed on a TT
David
prschatt@hotmail.com
  • 3 years later...
David
Anyone have a picture/description of where to TAP the vaccum line for a boost gauge?
