As I mentioned in some past posts, I cleaned my MAF in my 2000 Boxster this weekend because the Porsche dealer said the codes indicated a low voltage max limit had been reached.
The CEL is now off, but I've been getting some idle loping. When I come to a stop light, the idle drops to around 300 and then just before it stalls, it catches itself and goes back up. It does this about once every 3 to 5 seconds.
I'm not getting any other codes from the ODB, so where should I look first to remedy this issue?
Todd
I would check and see if your throttle butterfly is gummed up with carbon. Do a search here and you will see that many idle problems are related to carbon buildup and the throttle butterfly. Cleaning is also covered...
Thanks, I see there are several posts.
So, the 2000 with the e-accelerator throttle body can be cleaned without actually removing it from the engine? Did I understand that correctly from the posts?
Also, should the engine be running when I spray the carb spray/cleaner into the throttle body?
Todd
The throttle body does not have to be removed - but it is easier to clean with it off the car (IMHO). It can be easily taken off - four bolts and the electrical connector as I recall.
Here is one I removed at a work on cars day last year (2000 Boxster). Tariq had the same problem with an occasional erratic idle. Cleaning and reinstalling did the trick.
(my hand - Tool Pants pic)
The car does not need to be running when cleaning since you will need to open the butterfly with your fingers to clean around and behind it.
Sounds good - thanks.
So I just spray the stuff in there, and use the cloth you mentioned (and keep it away from the paint I understand too)
I'll let y'all'ins now the results.
Todd
