Can I use Vacuum pump to Change my brake fluid ?
I have seen the DIY guide from Loren as for changing the brake fluid. I want to fluch the entire sytem and replace with a new fluid. My local shop has a vacuum pump where you connect the hand pump directly to the bleeding valve on the caliper. When you pump, it will suck the old fluid, insead of pushing new fluid from the reservoir as it does with the Bleeder shown on Loren guide. Can I use my local shop hand pump and always make sure the reservoir is full when pumping ?
Does the guide applies the same way ? Start with the right rear wheel and always do the outer bleeding valve first ?
