I have a 2003 Targa which needs new rear brake pads. I recall reading somewhere that the Targa is based on the Convertible rather than the C2. If this is the case then the brake pads which I am about to order should be the Convertible type rather than the C2 type-- as apparently they are different.
Does anyone out there know if this is the right way to go?? Thanks!
From the 2002 Porsche Service Information Technik book:
"The engine, power train, basic running gear, body and interior of the 911 Targa is the same as the base 911 Coupé."
And... all 996 Carrera's except the C4S use the same brake pads. C4S uses the same brake pads as the 996 TT.
