All Activity
This stream auto-updates
  1. Today
  2. Yesterday
  3. Last week
  4. Maybe if it could soak through the canvas to the inside of the glass but it is a two-space door with the opener in the centre. I will look at the ceiling just in case. Thanks for stopping in
  5. Thank you, Loren. It looks like that shaft is held in place by what looks to be a snap ring that's labeled part 7. So perhaps the shaft will come out with some pressure? I tried prying on it a bit with a pry bar but decided I should wait until I can confirm that there isn't anything else holding it in place. I did see the section in the 101 projects book where they mention removing this shaft but they also remove a nut on the end of the flange before prying that shaft out. I don't see any nut on that diagram either so it looks to me like its just the snap ring holding it together. I think I'll try prying on it with a bit more force and see if I can get it to pop out. I'll report back if I can get it out.
  6. Item 13 is the radial shaft seal. (click the image to enlarge it)
  7. Garage door opener?
  8. I have a 2001 Boxster S with the 6-speed transmission and it's had a small transmission/differential leak that appears to be coming from the driver's side main shaft. This is the shaft that comes out of the trans/diff and has a flange on it that connects to the axel. How do I remove this shaft and get access to the bad seal? I've seen other instructions that include removing a nut or bolt in the middle of the flange but mine does not seem to have either (see pic below.) Thank you!
  9. Freezing cold morning but backing out of my garage I found a perfectly straight stripe of oil down the center of my windshield on the inside. It must have been thin enough to run down from the top all the way to dashboard, and wiping with a rag it smeared like oil or grease. I am thinking hood latch but what could make a drip like that and why now?
  10. My leak was from a headlamp washer hose. Just from trying the washer it drained the whole tank. Being too lazy to remove the front bumper I just cut it and capped the ends. Yours looks like dripping from the tank so maybe the seal where the pump installs.
  11. of course i understand. different people, different problems, different wishes and for sure some strange ideas like you have explained.
  12. No problem, some posts don't get answered for a simple reason: Neither form members nor staff are familiar with the particular subject, like swapping electrical or electronic components from different year or models. While we have seen a lot of unusual things over the years, like trying to transplant a 996 Mezger turbo engine into an early Boxster, I would be the first to say we haven't seen absolutely everything, and for the sake of fidelity and technical accuracy, sometimes we simply do not have a functional answer. 😉
  13. it was not any kind of critic, it was a observation. I see many posts in the past have lots of views, but no answer. Anyway i got answer somewhere else. the seats from 955 should fit as long as they have same features was told me. . I will see if i can get the seat out Thank you for paying attention to my post
  14. Just because no one has responded to your specific question, that does not mean that there is anything amiss with the forum. You may be the first to attempt this kind of swap, so YOU may be the best person to post the answer. 😉
  15. looks like this forum is dead . PITY
  16. Have you checked the wheel speed sensors? It seems to me that I one of these where a wheel sensor was giving intermittent wrong speed readings and the PSM mistook it for slippage and over compensated. Just a thought...
  17. I am getting a similar issue on left hand turns as well in my 2003 C4S with under 39,000 miles. The PSM activates inappropriately causing a very sudden and unexpected feeling that ABS is activating during even mildly spirited driving in my 2003 Carrera 4S that I acquired about a year and half ago. Occurs during left hand corners at mid-corner or just after mid-corner. This makes the car feel as if it’s going to understeer off the road. Occurs for a split second with PSM light coming on and then off for that split second. My foot is never on the brakes when this occurs as I’m usually rolling onto the throttle by midcorner. Doesn’t do it at lower speeds around the city but occurs when driving spiritedly in the canyons (but I should add that I’m not pushing it anywhere near its limit). It’s recently had new shocks, shock bearing plates, and suspension arms and links (all Bilstein and OEM parts) with stock alignment done. Wheels are balanced. Calipers were removed and repainted for cosmetic reasons. Tires are all within five years and appear to have worn evenly. Cold tire pressures 32-33 psi front and 36-37 psi rear. Clutch was changed about 6 months ago due to an unusual wear on the fork and while the shop was in there, IMS Solution was installed. A Porsche independent shop couldn’t reproduce the issue which wasn’t surprising since it never happens on city streets/highway nor has the PSM activation stored any codes. A second (smaller) independent shop says if the first shop couldn't figure it out, he wouldn't be able to. Any thoughts before I start down the rabbit hole of replacing tires and parts (such as the ones mentioned here, Porsche PSM Failure: A Mechanic's Guide To This Common Nightmare)?
  18. Try 5034
  19. need Radio Code for a CDR-220 with serial number X5035237 please.
  20. Earlier
  21. hello everybody. bought a 957 for winter which i better didnt buy. to many issues. Some specialist / last owner / changed the batterie , but not the way it should be. screws in front of the seat did not come out , so he tried a different way. i dont what he did but he destroyed in some way the mechanism under the seat. up and down, forward backwards , everything doesnt work like it should be. I am thinking to buy a used seat and change it. My question : Is it plug and play and are the seats from 955 fitting the 957 ? Thanks a lot for your assistance
  22. which side is it ? left or right ? what is the door ? left part or right part of the picture ? is the door hanging down ? the reason is just age - usually. i had a hanging door, bought some matal plates / Chims. see video. for me it was working
  23. 2006 CAYENNE 955 4.5 V8 DRIVER SIDE PRIMARY CAT REPLACEMENT Full size pictures can be found HERE Writing this down hoping it can help out another pepper owner. SKip to the bottom if you want the short version. Had to replace the drivers side (LHD) primary catalytic converter as the flex pipe had completely corroded away and was flopping loose in the wind. I got lucky and found an aftermarket one on eBay for significantly less than what the dealer would charge me. You’ll need an assortment of tools for the job: Jack Jack stands Ramps for rear 10mm sockets 12mm sockets 13mm sockets Numerous extensions Wrenches in above sizes and flex head ratcheting are awesome 22mm O2 sensor wrench or crowfoot Straight ⅜” and ¼” ratchets and breaker bars for extra leverage as needed. Flex head ⅜” ratchet Long flathead screwdriver to open up the clip holding the O2 sensor wire T25 screwdriver or bit for your screwgun for trim pieces #2 screwdriver or bit for your screwgun for trim pieces Total actual work time was about 8 hours. I could have done it in about 5 or even less if I was truly ambitious, but was taking my time and making sure I didn’t break anything in the tight space. The time also included jacking up the car, removing the underneath skid panels, engine compartment plastics, drivers tire and wheel well liner as well as reinstalling them. See Pelican Parts for the skinny on accomplishing all of those tasks. I’ll skip those tasks here. https://www.pelicanparts.com/techarticles/Porsche_Cayenne_Tech.htm Also crack open the rear hatch and block it from locking as you’ll want to disconnect the battery ground. Here is a video that shows how. Super easy and never knew myself. No need to flip the seat. How to disconnect battery ground in Porsche Cayenne (955) I will preface my replacement with the added bonus of the car having the secondary CAT delete already done. So no fighting with those. So under the car, first things first was loosening up the connection between the tailpipe section and the straight pipe, which was connected to the primary CAT. As the existing bolts on the CAT were rusted and frozen, I just snapped them off knowing they would be replaced anyways. Don’t waste your time on PB Blaster or heat. Just break them off and be done with it. So with the easy work complete now it’s time to dive into the fun part. Move up under the car so you’re looking straight up where the CAT meets the exhaust manifold. You’ve got 3 bolts above you that you’re wondering how you’ll ever get to them without taking out the front O2 sensor and even then how. Give them a spray of PB Blaster or your choice of penetrant. Now move to the front of the car in front of the sway bar, there is an opening where you can see the 3 nuts on the exhaust manifold. With a combination of extensions you can reach the nuts with a 12mm socket. You can let them soak for a little while as you have another cup of coffee or beverage of choice. At this point you may be wondering why I haven’t mentioned the O2 sensor on the top of the CAT pipe. Well, because I drove myself crazy trying to figure out how to get it out. I went after it 8 ways to Sunday. From the top with swivels and extensions and the same from underneath. I could barely get a finger over it and did manage to get the socket on it but then couldn’t get it broken free as the leverage just wasn’t there, or the socket/crowfoot slipped off. Needless to say, I wasted about an hour or so on this and questioned my seemingly foolish decision to approach this project. In the process of doing all of this, I figured out I needed to remove the middle skid plate support bracket for more room to reach up in the small area. Working by myself created new opportunities to be resourceful, or stupid depending on point of view. Since I was already committed to this endeavour by already removing, AKA breaking, the lower sections of exhaust piping, **** the torpedoes and full steam ahead. I ended up just unbolting the CAT from the exhaust manifold, dropping it down and slightly rotating it. At that point I had a good view of the O2 sensor and slipped the O2 sensor socket right over it with a breaker bar attachment. With the room to get leverage and a straight shot at it, it came loose with a marginal amount of effort. Unscrewed the sensor by hand and pushed it behind the steering column. Now for the next problem. The CAT was just big enough to not slide out with the heat shield of the steering column shaft in place. So, prop the CAT in place and remove the heat shield (2-10mm bolts), giving that extra ¾ of an inch. And so with a small amount of finagling, out she came. Could I have worked a little more on it and fought it out? Maybe. But for two 10mm bolts, easy choice. At this point in time, I called it for the day as I was now about 5 hours into the whole job. Sunday morning - here we go for part 2. Now knowing how it came out, it should make it easy to go back in. And yes, it was. Reverse the process of the removal. Slide the new slimmer CAT up into the general position it needs to be, let it rest on the other parts while the O2 sensor is installed. I did unclip the connector up in the engine bay and hang it from the hood so it would spin freely while installing it. A tip I saw elsewhere, thank you. Now push the CAT up into position and viola!. NO! WAIT! The mounting bracket is farther forward than on a stock CAT by about a ½ inch and slightly rotated off the axis of alignment from the engine bracket. The CAT won’t go all the way forward to mate with the exhaust manifold. So… Now it’s pushing, rotating and mild cursing to get it around the engine bracket. In the end, I got it together. Final decision on the bracket, it’s staying unbolted. Not the preferred method, but that’s how we’re rolling since I don't have a welder anymore to move the bracket on the CAT. At this point I was able to get my hand up to get the nuts on the ends of the bolts and finger tight them. Slide around to the front with the long extension and reach in to tighten them up. Now, if you’re lucky, you may have an air ratchet or a battery operated ratchet, which I did, to tighten them up. Do so at this point. Back to the middle of the car to reinstall the short pipe piece to the flex end of the CAT and to the tailpipe. Reinstall the middle skid plate support bracket and you’re just about complete. I hope for all of you who lasted this far have good luck getting around the secondaries if you still have them or figure an alternate plan for that. Time to start the car before I put everything back on and drop it to the ground. Hook up the battery (sparky, sparky), key in the ignition, hand pushing the brake AND… nothing. PANIC!!! I know there’s power. The interior lights come on, chime is going ding-ding. Again.. Nothing. Hold on, let’s breathe a second. Oh lord, the wife will kill me if I killed her car. 3rd time, small prayer to Stuttgart and… SHE LIVES AND BREATHES!!! And much quieter too. Do a couple of start-stop operations to double check it’s all working and then off to reinstall all the plastics and drop her to the ground. I will say, fighting to get the wheel liner on, is an extraordinary test of patience and will power. I think I fought that alone for over 30 minutes. If anyone has tips for that process, I’d be eternally grateful. Couple of side comments on this. The CAT I purchased was an aftermarket unit I got off of eBay and have no idea who manufactured it. There were no studs in the flanges, just 3 bolts and nuts per flange. I was worried they were going to fall out during the install, but the new gaskets held them in place as the holes were the right size to screw the bolts through them by hand. I know this helped during the reinstall and not having to bend or cut off the bracket on the CAT. For the heat shield, some places had said to unbolt the steering shaft and move out of the way entirely. I did not want that headache to do a realignment of the shaft/steering wheel. So I just did the minimum I thought would work. Now that you’ve gotten to the end of my story, I hope it will give someone else the courage to take on the project. Take your time, step back, breathe from time to time and don’t rush it. It will happen. Please make sure to tip your waitress. SHORT VERSION Put car on jackstands or at least front end Put rear of car on ramps if only jackstands in front Disconnect battery Remove front left tire Remove wheel well liner Remove underbody skidplates/plastics up to bumper Remove heat shield from steering shaft Remove middle skidplate support bracket Unbolt/snap off bolts from primary CAT flex pipe to tailpipe/secondary CAT Remove short tailpipe section if secondary delete performed From front of car, reach in and unbolt the 3 nuts holding primary CAT to exhaust manifold Drop CAT down and rest it on car Using O2 sensor socket, reach up into area and remove sensor Pull CAT out of car Push new CAT up into the void and rest on car Install O2 sensor Push CAT up to exhaust manifold and bolt together Install engine support bracket (if applicable) Install tailpipe section to flex pipe end of CAT Install skidplate support bracket Install skidplates Install wheel well liner Install tire Lower car to ground Install engine compartment plastics Reconnect battery Start car CELEBRATE Now if someone can share an easy way to do the passenger side......
  24. Thanks - we'll keep this thread so it can help others in need.
  25. FYI, it is confirmed, 99970346240 is the correct P/N, I've plugged all empty holes now, a total of 8 in the rear body area, behind the intercoolers. It does not show in any of the 996 PETs, the parts guy found it in the Cayenne 951 PET. May be in others as well.
  26. It's a plug. Me and my parts guy at the dealer now believe it is 99970346240. I've ordered 10 of them, I will know in a few days if that's what they are.
  27. It that a plug or plastic pop rivet? I am only finding the plastic rivet.
  28. I can't find the P/N of the plastic body plugs found under the intercooler areas, 996TT. They're 10mm inner diameter, 17.5mm outer diameter and are hat shaped. Out of the 8, I only have one survivor and would like to put them all back. Here's a photo, next to one of the M8 screws that holds the intercooler frames.
  1. Load more activity
