All Activity
This stream auto-updates
  1. Yesterday
  2. Last week
  3. Earlier
  4. Try 0182
  5. Hi help needed. 97 993 cr-21 BE2180 V5003094
  6. Based on the actions you described I would guess window regulator. Once replaced you can test the window with the door panel off and see if the door handle microswitch is working properly or not.
  7. Thank, that’s the plan. Once the panel is removed, is there a tell tale sign to diagnose one way or the other?
  8. Without a PIWIS diagnostic - it will be difficult to tell whether it is a microswitch issue or a bad windows regulator (cable). Either way the door panel will need to come off for repair.
  9. Taking a chance this question will be answered. Hopefully, it will given I didn’t get a full year from my membership lol. 2001 996 C4, passenger window is having issues. Window drops waaaay down automatically when rolled up. See photo. If window is in the up position when the door is open, it does not drop slightly to close the door and the glass contacts the cabriolet top when closing the door. Then, once the door is closed, the window automatically opens six inches on the up cycle inexplicably. When rolling down, the window squeaks and the rubber seal collapses into the sill and pops back out when the opening cycle is complete. Please see attached videos. Not sure if there is something wrong with the track, a sensor, both? Thanks is advance. IMG_4116.mov IMG_4115.mov
  10. FINALLY FIXED- First- Loren and JPFLIP, thank you for all of the advice over the years. This site has been an amazing resource. I am sad that a company with deeper pockets like Pelican Parts couldnt take over the forum and retain all of the fantastic information herein. That said, I want to give the final update on the GT3 issue and fix. Ultimately the car had gotten to the point that after warming up, the fuse would blow when starting from a stop. I got good at replacing a fuse in the middle of traffic the last time I drove it...After a new ECU and point to point shooting of all the wires, my Indy guy and I agreed it was time to drop the motor and comb through the wiring. Ultimately that wasn't needed. A few years ago, after the factory transmission mount disentegrated, I installed the Green Cantrell Motorsports Street Urethane mount. I never had any indication driving that there was an issue (clunking, etc) that it had failed. As the tech was de-paneling the underside of the GT3, he found the mount had failed and the resultant sag had a plug on the transmission case (Vacuum changeover valve for transmission cooler) resting on one of the coolant lines and had chafed one of the wires to bare metal resting on the pipe. the car would warm up and when the ECU/DME sent the signal to open up the valve for cooling - Boom. Repaired wire/plug and replaced mount and runs great. Still a little laggy at 2000 RPM but rest of range is lovely as always. Just wanted to get this in the system so that people with this fuse blowing aren't completely focused on the Variocam Solenoid wire which seems to be the "usual suspect". Pics to include. Thank you again for all of the effort and support for our enthusiast community.
  11. That worked, thank you! 😊
  12. Try 0574
  13. Hi there. Looking for a code as I have a (new to me) 986 with a Becker CR-22. Serial: Y5022379 Thanks 🙂
  14. Try 4870
  15. Hi Looking for help! 2001 911 C2 CDR220 Becker Radio Model: 4462 Serial no: Y5060408 Thanks in advance for the help!
  16. The most accurate font match for the Porsche emblem/badge lettering is the 911 Porscha typeface (created by Iconian Fonts). If you need the TTF file for decals, vector graphics, or print projects, you can grab it here 911 Porscha font - Dafont DAFONTDL.COM Discover 911 Porscha, a highly versatile sci-fi font designed for professional graphic work. Perfect for crafting high-impact logos, editorial layouts, marketing posters, and apparel branding. Grab the secure installation package now to unlock its full character set. It covers the regular, bold, and italic styles used across different Porsche models.
  17. Is the metal ferrous (can be picked up by a magnet)? A photo would be helpful.....
  18. Try 0869
  19. Hello. Looking for a radio code for my 986 Serial nr 15076700 BE4462 CDR 220 Thanks!
  20. Hi All, I am retro fitting an aftermarket camera into the factory automated pop out on my 2009 Cayenne Turbo S. I have an aftermarket head unit which is the pioneer DMH-WT8600nex. I have successfully integrated it into the Porsche system including the fiber optic and I now have remotely run wires for the new retrofitted pioneer BC-10 camera into the mechanical body. I reconnected the PCM temporarily to re-enable the backup camera pop out and then pulled fuse 55 to reset the system because I couldn't find the setting... I can confirm that it reset and when shifting to reverse the mechanical body did operate but when I reconnected the pioneer head unit everything worked except the mechanical body coming out. I'm hoping that somebody is familiar with the pinouts on the PCM or has a diagram so that I can figure out which pin runs the trigger for the mechanical pop out. TIA! p.s. I have done a preliminary run with a multimeter verifying each lead that I could reach that didn't have power when not in reverse but none had power when shifted into reverse... the only step I can go from here is to get my needle leads out. Update: I ended up using my needle leads and tested all the wires to the factory harness. I can say that the lead is in the blue block that connects to the micro pins, I can also say that it is not a standard voltage signal. Most likely it is a canbus signal that activates something remotely like a relay. Today I will probably pull the voltage of the factory motor lead and just run a new circuit for it. Hope this can help someone in the future.
  21. I do not know the cause but there is metal in the oil. I had the IMS bearing replaced 4 years ago but sadly the warrantee has expired. I had a 60k mile check up at a Porsche dealer less than 2K miles ago but they missed it and claim to have no obligation. Sad... Option 1: Replace the engine. $25k to $30 is my best guess Option 2: Sell it as is Thoughts? Advice?
  22. Anyone can help me to find valves of the coil. So i can order new one. Im at the point where is no turning back 🙂
  23. That worked! Thanks so much!!
  24. Try 6707
  25. Hi Loren, Would you please provide the code for this Becker CDR 210 SN: V5011320 First character could be a "U". Many thanks!!
  26. Perfect! This works. Thanks again and have a great weekend!
  1. Load more activity
