All Activity
This stream auto-updates
  1. Yesterday
  2. Try 6707
  3. Hi Loren, Would you please provide the code for this Becker CDR 210 SN: V5011320 First character could be a "U". Many thanks!!
  4. Perfect! This works. Thanks again and have a great weekend!
  5. Last week
  6. Try 8386
  7. W5011176 I need the radio four dugit code
  8. Porsche use to have a sticker on the inside of the hood which, if I remember correctly had the vin and other identification number for the car & options. Does Porsche put that on anymore - the sticker? My ‘06 had it but not the new 992.2 I just picked up. Tks!
  9. Try 1634
  10. Just got a Becker CR-210 (BE2182) with S/N V5008528. Can you help with code? Thanks.
  11. Thanks so much!
  12. Try 9830
  13. Becker CR-1 SN: POCR-1MO812515
  14. Earlier
  15. Try 9290
  16. hmmm!?! Thanks Always, It depends...
  17. Without actually seeing the car, it would be pure speculation of what is needed, and caliper studs or bolts, it still has to come apart, but sometimes using studs actually slows down the process because they are simply in the way when the caliper has to come off............
  18. Oh, BTW Has Brake Studs installed: Does this reduce labor time? Thanks, JJ
  19. Thanks. Your good thoughts are echoed and embedded in the local shop's idea - to replace all - rotors, sensors and pads. Interesting that they would like to do both front and rear -- when only the front seem to exhibit low-speed squeal. Now the question is: How long can we live with the functioning system? Appreciate your input, JJ
  20. New to me 911 with a CR-220 type 4362 Serial no Y5024557 An unlock code would be greatly appreciated!
  21. Most noise issues are related to how the pads were installed; did they use the correct lubricants and install noise dampeners if so equipped? If the current pads have not been done correctly, just replacing them will typically get you to the exact same place.............
  22. Good Day, Recently purchased an excellent 981S. It has Ferrodo Pads installed -- and they SQUEAL! Help Please -- Need recommendations for replacement Brake Pads. Thanks Folks!
  23. Recently purchased a 2019 718 Cayman. I expected it to have Apple CarPlay, but when I plug into the USB in the center console, the only option I get is iPad. The car has Bose and Navigation, but not the phone box. Is there anything like a software update available that will enable CarPlay through the center console USB? Sadly, the dealer has not been much help. TIA for any help.
  24. Are you still able/interested in producing this part? I’ve done the zip tie fix which is working at present but your solution looks ideal. If you are able, could you please let me know timing, cost, etc? I’m in Colorado. Thanks!
  25. What a pain. Let the go down to 30 miles left to empty. Fuel light has been on since the 50 mile mark. The message “consider remaining range” starts popping on and off. Stopped at a gas station I do not like. I put 4 gallons of gas for another 15 miles to go. Restarted the car to go, no change in the display of warning message, low fuel light, and gauge is like o didn’t put 4 gallons in the tank. I have only filled this car once before and had it for a month now. 2009 997.2 C4S.
  26. It’s works!!! Super!! Thank you very much.
  27. Unbelievable! Thank You!
  28. Try 7032
  1. Load more activity
