All Activity
This stream auto-updates
  1. Yesterday
  2. Thank you. That is it. Appreciate your help Loren
  3. Try 5016
  4. I hope I can get some help in getting the radio code for my Becker CDR-210 Serial #: W50235 10 Thank you in advance for your help.
  5. Last week
  6. Earlier
  7. Update: 1100 miles and 24 days later. No sign of coolant anywhere. Level seems steady. Car behaves correctly. The only real problems are: the blend door foam <sigh> and the fact that the AC stayed charged for 48 hours. But that is a story for another post.
  8. Those sponges disintegrate into dust after so many years. I suggest to vacuum the line to get any broken filter bits out.
  9. The hard plastic vac line tend to crack after so many heat cycles esp around heatshrinked connection. black tape / heatshrink tubes over it don't work but 1/2" fuel line might seal them over it; check for fitment. it will be one repair after next. You push/pull a little too hard, or drop tool on it, the whole thing can break apart. the pump on pass side near strut tower, silver guy with audi/vw sticker, seems reliable enough, but anything with electrical motor after 200k is suspect.
  10. Self-update: So I read up on the issue and I found, among other things, https://www.renntech.org/topic/44251-996tt-strange-coolant-leak/ . The experience would be consistent with mine, multiplied by 6.5 years as opposed to three days. The part where I'm concerned, of course, is the subsequent sudden failure when the glued in connectors decide to give way - if that is indeed what is happening. On the other hand, I do not know that it makes sense (...) to pull out an engine to get out the coolant distribution block, force out the connectors and bond them again 'just in case', but I hate the concept of not being able to trust that the car won't decide to take a break on me. From all the videos I could find, it can be *pretty difficult indeed* to say the least to pinpoint things further but.. I'm open to ideas.
  11. No sir, the oil was positively beautiful. And - no smoke from the tailpipes either. I'm really at a loss.
  12. No oil in the coolant. Any coolant in the oil?
  13. As I mentioned in the other post, my US 996 is back on the road. But. But, there was an interesting mystery: the coolant was way down. As in, down by 3 quarts. The interesting part is: there was none on the ground, there was none in the engine bay (I assume the water pump has the usual weep hole which would cause pretty visible residue and/or spray. There was no coolant in the oil and, as far as I could tell, no oil in the coolant. What's my next diagnostic step? I am at a bit (a lot) of a loss. Thank you everyone!
  14. So it ended up not being five years. It ended up being almost seven. The car was parked in October 2019. I put it back on the road today - in June 2026. How did it go? Amazingly well. I got out as much of the old fuel as I could - and it was not all. Put in a can of Seafoam (advisedly) and 5 gallons of 'fresh' gas. Left it to think about what it had done for an hour or so. Put in a new battery and turned the key - no, I had not changed the oil yet. It caught as fast as it could prime the fuel rails. From key turn to running, less than ten seconds. I was expecting the boxer cloud - not even vaguely. Drove it out of storage to where I could work on it, ~0.7 mi going 30 mph in fifth. It was running a little rough but not... bad. Got it to where it needed to be. Stopped it. Went in to grab some tools. Swore because the car was not centered in the lift. Restarted it -> it started like it did in 2008 when I bought it. Centered it in the lift, up it went, changed the oil. Oil was from 11/17 and had ~4800 miles on it - and looked, smelled and felt just fine. There's a distinctive feel to oil past its prime - this wasn't it. Put in 5W50 - it's summer after all and this car never sees 40F weather. Washed the thing... there are only two problems that I'll tackle in another thread. 1) AC needs charging. I have all the equiment and 30 lbs of R-134 (from Dupont... sorry, Chemours). That's next on the list 2) The coolant was VIOLENTLY down. As in, it took three quarts of distilled water to bring it back to level ... but there were no stains anywhere, there was no mix ... any idea where it might have gone? I shall change the coolant anyways, the car is on the factory fill from 09/2004 and the additive package is a remote memory by now, but I'd like to understand WHERE it's going. Oh yeah, also: tires that have been sitting for six+ years and were down to 15 PSI may cause you to experience some SLIGHT VIBRATIONS for the first 10 miles of driving. For 'did I forget I had snow chains on' values of slight. Anyways - one more thing to love about this car. My S54 powered M3 was a LOT more difficult to resurrect after a shorter stay... but that's another story for another forum.
  15. Will a the sport exhaust off 14-14’ 958 GTS bolt straight onto 2011 958 S? Also will the valves be open full time if no lines installed for the on off switch?
  16. Sound absorber - so if you want to be able have a conversation while you drive I would leave it in place.
  17. Lost Radio Codes DO NOT START A NEW TOPIC FOR A LOST RADIO CODE. DO NOT EMAIL ADMINS. Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread.
  18. Turns out it's a 'Butyl Plate'. A butyl plate on an engine cover (or a car hood) is a sound-dampening pad made from synthetic rubber and often backed with aluminum foil. Its primary job is to act as a vibration damper and noise barrier to make the cabin quieter. Learn something new every day... now... to remove it or not..!!??
  19. Could I get a Radio code for my 2001 Boxster radio serial number X5033316 Thank you
  20. As per the title... what's it for? I'm not looking for 'guesses'... i want somebody, if there is anybody, to tell me FACTUALLY the reason for it..? I'm thinking about cutting it out, to get some more engine sound...
  21. Porsche dropped that part in 2008 so it might be best to find one at a salvage yard. Sorry.
  22. 1998 986. The hp hose connection at the power steering pump continues to leak. I have tried sealing with teflon tape and pipe joint compound. I'm not sure how much torque to put on the nut. Any ideas?
  23. Thanks for sharing this. Is there a wiring diagram to check the wiring and pin connections? I am assuming I will be checking the MAF pins and some points in the fuse box.
  24. I'm going to remove and clean the injectors I think
  1. Load more activity
