All Activity
This stream auto-updates
  1. Today
  2. Yesterday
  3. Does not look like an expansion riveret. Maybe the door plastic cover is held in with three T5 screws.
  4. I am having a problem removing the cover in the door area to get to the nut that holds the tank. The screws are difficult to remove due to the door swing. The part is called a expansion riveret A6,0 x 12,0 Any help in telling me what tool to use to remove the three expansions rieverets? A T10 does not work. Paul
  5. Last week
  6. Does anyone have any step by step info on how to replace the plastic heater pipe with the aluminium pipe part # 94810606910. There was an attempt made on a Rennlist posting but no conclusion. The 6 Speed site shows the before and after, but very little about the how, and it appears that the engine was dropped anyway to replace the rear distribution manifold. I don't want to drop the engine, that's out of the question, so any tips would be welcome. I have removed the intake manifold and fuel rail to replace the starter for an intermittent partial crank starter issue. Found an abandoned mouse nest in there and the PCV vacuum control wire and a knock sensor wires were completely chewed through and the wires on another knock sensor were gnawed exposing the bare wire. I have replaced two knock sensor plugs and spliced the vacuum valve wires by soldering and covering each conductor with heat shrink tubing and then covering both with another heat shrink tube and then wrapping them with high temperature glass cloth tape and the wrapping them again with Lakota anti-rodent tape. Since I'm the valley, I want to replace as much as I can within reason; the starter as mentioned as well as the knock sensors, the heater pipe 94810606910 and the plastic coolant vent pipes, the water pump and thermostat. I also replaced the manifold gaskets as there was signs of vapour staining around a couple of the intake ports. It's a 2008 CTT with over 190000 km, the body and frame are in excellent shape and the it runs well, no MIL and there were no codes on my Bluedriver scan. The previous owner followed Porsche's guidelines and had the oil and filter changed at 20,000 km and once a year intervals at the Porsche dealer which probably led to the stretched timing chain and cracked and deteriorated chain guides which I got repaired with assistance of an aftermarket warranty shortly after I purchased it at 180 000 km. I change the oil at 5000 to 7500 km intervals or once a year which ever comes first, I don't drive it all the time as I have a winter beater and a summer beater too to run local errands.
  7. Thanks a lot friend, you made my day!!
  8. Try 4897
  9. Hi Guys, bought a cdr220 to replace my broken 210. I would need the code. Serial Y5044708 Type BE 4462 Thanks a lot!!!!
  10. Earlier
  11. I need help with radio code. S/N is. V5016412. Thanks
  12. Thank you. That is it. Appreciate your help Loren
  13. I hope I can get some help in getting the radio code for my Becker CDR-210 Serial #: W50235 10 Thank you in advance for your help.
  14. Update: 1100 miles and 24 days later. No sign of coolant anywhere. Level seems steady. Car behaves correctly. The only real problems are: the blend door foam <sigh> and the fact that the AC stayed charged for 48 hours. But that is a story for another post.
  15. Those sponges disintegrate into dust after so many years. I suggest to vacuum the line to get any broken filter bits out.
  16. The hard plastic vac line tend to crack after so many heat cycles esp around heatshrinked connection. black tape / heatshrink tubes over it don't work but 1/2" fuel line might seal them over it; check for fitment. it will be one repair after next. You push/pull a little too hard, or drop tool on it, the whole thing can break apart. the pump on pass side near strut tower, silver guy with audi/vw sticker, seems reliable enough, but anything with electrical motor after 200k is suspect.
  17. Self-update: So I read up on the issue and I found, among other things, https://www.renntech.org/topic/44251-996tt-strange-coolant-leak/ . The experience would be consistent with mine, multiplied by 6.5 years as opposed to three days. The part where I'm concerned, of course, is the subsequent sudden failure when the glued in connectors decide to give way - if that is indeed what is happening. On the other hand, I do not know that it makes sense (...) to pull out an engine to get out the coolant distribution block, force out the connectors and bond them again 'just in case', but I hate the concept of not being able to trust that the car won't decide to take a break on me. From all the videos I could find, it can be *pretty difficult indeed* to say the least to pinpoint things further but.. I'm open to ideas.
  18. No sir, the oil was positively beautiful. And - no smoke from the tailpipes either. I'm really at a loss.
  19. No oil in the coolant. Any coolant in the oil?
  20. As I mentioned in the other post, my US 996 is back on the road. But. But, there was an interesting mystery: the coolant was way down. As in, down by 3 quarts. The interesting part is: there was none on the ground, there was none in the engine bay (I assume the water pump has the usual weep hole which would cause pretty visible residue and/or spray. There was no coolant in the oil and, as far as I could tell, no oil in the coolant. What's my next diagnostic step? I am at a bit (a lot) of a loss. Thank you everyone!
  21. So it ended up not being five years. It ended up being almost seven. The car was parked in October 2019. I put it back on the road today - in June 2026. How did it go? Amazingly well. I got out as much of the old fuel as I could - and it was not all. Put in a can of Seafoam (advisedly) and 5 gallons of 'fresh' gas. Left it to think about what it had done for an hour or so. Put in a new battery and turned the key - no, I had not changed the oil yet. It caught as fast as it could prime the fuel rails. From key turn to running, less than ten seconds. I was expecting the boxer cloud - not even vaguely. Drove it out of storage to where I could work on it, ~0.7 mi going 30 mph in fifth. It was running a little rough but not... bad. Got it to where it needed to be. Stopped it. Went in to grab some tools. Swore because the car was not centered in the lift. Restarted it -> it started like it did in 2008 when I bought it. Centered it in the lift, up it went, changed the oil. Oil was from 11/17 and had ~4800 miles on it - and looked, smelled and felt just fine. There's a distinctive feel to oil past its prime - this wasn't it. Put in 5W50 - it's summer after all and this car never sees 40F weather. Washed the thing... there are only two problems that I'll tackle in another thread. 1) AC needs charging. I have all the equiment and 30 lbs of R-134 (from Dupont... sorry, Chemours). That's next on the list 2) The coolant was VIOLENTLY down. As in, it took three quarts of distilled water to bring it back to level ... but there were no stains anywhere, there was no mix ... any idea where it might have gone? I shall change the coolant anyways, the car is on the factory fill from 09/2004 and the additive package is a remote memory by now, but I'd like to understand WHERE it's going. Oh yeah, also: tires that have been sitting for six+ years and were down to 15 PSI may cause you to experience some SLIGHT VIBRATIONS for the first 10 miles of driving. For 'did I forget I had snow chains on' values of slight. Anyways - one more thing to love about this car. My S54 powered M3 was a LOT more difficult to resurrect after a shorter stay... but that's another story for another forum.
  22. Will a the sport exhaust off 14-14’ 958 GTS bolt straight onto 2011 958 S? Also will the valves be open full time if no lines installed for the on off switch?
  23. Sound absorber - so if you want to be able have a conversation while you drive I would leave it in place.
  24. Lost Radio Codes DO NOT START A NEW TOPIC FOR A LOST RADIO CODE. DO NOT EMAIL ADMINS. Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread.
  1. Load more activity
