All Activity
This stream auto-updates
  1. Past hour
  2. Yesterday
  3. Timing chain tensioners wear pads. I bought a neglected Boxster where the owner kept driving and the pieces eventually blocked the oil pickup and wiped out a rod bearing. You should change them even though they’ve likely been done once at that mileage.
  4. No better sound than a sport exhaust on a Porsche!
  5. That is just magic! Thanks. I mostly like to hear the engine purr but I do like to have everything working.
  6. Try 9085
  7. I picked up a 1998 Boxster and the radio code is nowhere to be found. Please help. Serial number is. V5016831 I looked through and tried all the codes listed with no luck. Thanks
  8. Last week
  9. I was just thinking about cutting the gray pink wire myself. Were you ever able to resolve this? Our stories seem very similar.
  10. Just going to keep reporting on things that haven't resulted in a successful calibration. Fuses checked. Battery on charger and showing 14.34v. Mini switches in the latch cleaned, and all report anticipated actual values in PIWIS 38.25 with one exception. The switch depressed by the fork arm when the top makes contact with the windscreen frame reports results the opposite of expected values: when in the service position, it reports Convertible top raised. When manually depressed, engaging the switch, it reports Convertible top not raised. Back and forth, 1:1 with depressing and releasing the "fork." The one other anomalous actual value reported is speed which continues to show > 5kmh. Parking brake is engaged and that is reflected in actual values. Latch bench tests as expected: deploys under power, retracts when polarity is reversed. Then latch was reset per the FSM before reattempting calibration. Side potentiometer arm (reminds me of a large paperclip 🙂) is intact (unbroken) and captive by pin on hydraulic ram so that pot moves freely when the ram moves. (Not captive as in bound.) Side flaps lubricated and behave as expected (up and down) when actuated via drive links, with anticipated actual values reported. (Up is up, down is down). Hydraulic pump has fluid, no leaks, and when power is directly applied, goes up and down (when polarity reversed) as expected. Clamshell motor has been disassembled and relubed and bench tests as expected. Installed, it seemed to be binding, so I completely disassembled the clamshell transmission. No broken cables or gears, and I cleaned out all the crud before relubing everything. With everything reinstalled, when power is directly applied to the motor, clamshell smoothly goes up and down (when polarity reversed). Potentiometer set to 6.24k ohms on bench; tests 6.28k ohms installed onto clamshell transmission on car. All points of the top frame that move have been lubricated with teflon dry lube. When the hydraulic fluid relief valve is open, the top can be raised and lowered by hand with no binding. When I depress the #3 microswitch (latching hook, windscreen frame) with my finger, the rear windows will go up when their respective buttons are pressed. When released, they will not. As expected. When attempting to calibrate, nothing moves and "Function inactive, end position not reached." Control module replaced with same part number: when attempting to calibrate, nothing moves and "Function inactive, end position not reached." I'm running out of ideas. It's as if every single component works exactly as I'd expect it to work, but in concert, the software is like, "nope." On a lark, I even asked Durametric to calibrate it. "ECU returned a negative response. Sub function not supported / invalid format."
  11. 2004 Boxster S. 165k miles. New to me. I found some small, black, plastic pieces (smaller versions of the one in the picture) in my oil filter after a recent oil change, and when dumping the old oil I found a single ferrous metal shaving (no more than a few mm wide). I drained the fresh oil and dropped the oil pan to investigate further. The picture is what I found in the pan. The dust stuck to the magnet came from the drained oil. The strips next to the dime were one piece stuck in the oil pick-up screen, and I'm pretty sure it is a piece of the sealant. The amber, glass-like bits are brittle and transparent and very smooth. Thoughts?
  12. Hi there, Disconnected the battery on my new (to me) 986 with CR22. S/N is 15040196. Could I get the code please? Thank you!
  13. Earlier
  14. Brilliant! Thank you!!
  15. Need a radio code for s/n t5003851 please model CR210 97 986
  16. The dash lamp for the top comes on during power on (bulb check) then goes out. And stays out. Always. No matter the state of the top. Latched, unlatched, service position, down and stowed. No light. That doesn't seem normal. I took the controller out and magnifying glassed it for obvious solder issues but came up with nothing. Not really a surprise, visual check isn't worth much.
  17. Maybe related but check that you have this installed, its for cars in california and other restrictive emissions areas and its only 14$ and easy to install. Part number is 997 201 944 00 https://www.pelicanparts.com/More_Info/99720194400.htm?pn=997-201-944-00-OEM&fc=Y Article on how to install
  18. Im a DIY guy and the key fob is the only reason i take my car to a dealership. They engineered this against global theft , which was a bigger problem in the 90s, but they require you to bring a title certificate and drivers license and then they program it (and your other keys if you have more than one. each has their own profile such that each key triggers customized seat-positions and stuff) for about one hour labor which costed me about 280$ They do require that the blade , if needing cut, be purchased through them as authentic, and charge 80$ i think on top of that. I went into the suburbs of my city where it was a bit cheaper and quickly done. they keep these in stock at all dealerships.
  19. I just recently reqired those. each wheel has their own unique part number for the replacement which comes with connectors to splice in the five wires and replaces the main-connector. Best price i found was 130 each from Sunset Porsche. All four of the wheel sensors turned out to be just fine (and very difficult to remove and replace). Front: 996-612-957-00 Repair harness kit - (Left) 996-612-958-00 Repair harness kit - (Right) Rear: 996-612-953-01 Repair harness kit - (Left) 996-612-954-01 Repair harness kit - (Right)
  20. It's solved now, this is what I did, and what I think helped. I am also using a Blaupunkt (110 Liverpool). Mine was 100% an alternator whine, so only when the engine was running. If yours is whining even without the engine running it's likely to be the grounding of the head unit. All the speakers I think use the chassis as the negative terminal (if I remember). So maybe just run a new grounding wire from the front bulkhead to the head unit, although if I remember the original unit used the original stereo bracket as the grounding point, so maybe there's somewhere to ground it near the head unit. For my car, the hypothesis I formed was that when the original head unit was installed, the ground for the amp was shared with the head unit. When that was replaced, I think the amp no longer shared the same ground / or didn't have a main ground. 1. So the first thing I did was to cut the ground wire on the amp and route it to a chassis bolt. That didn't help. 2. I then wired a new ground wire to the head unit and shared that ground with the amp. This didn't help, so I would do these two first steps only if the next few steps don't work. 3. I bought some ground loop insulators for the amp from Aliexpress and tried a few, some reduced the whine but didn't eliminate the whine. But I'm not sure if it was the heat or the load on the capacitors, they cut out the power to the amp intermittently after about 20 minutes of using the stereo. I changed it one that ended up being more stable. 4. I then bought another voltage regulator/insulator that connects to the head unit directly that I found recommended in an older forum post. I think that was the one that truly fixed it for me.
  21. Hello, and if I may ... Following our first Cars'n Coffee here in my home town, I was forced to put my 986 'on hold' while I decided to fix or replace my transmission. The car is a '97 2.5 with an A86/00 transmission. A search locally has found a low mileage transmission from a 2001 S. A response from the seller indicates it to be an A86/20 transmission. Should I consider this change and what can I expect or may have to also replace with the 'upgrade' besides possibly the TCU Thanks!
  22. Thanks, Loren—I had not noticed there are three microswitches in the latch, I'll look at that 3rd one next.
  23. Hello Vic. Just saw this post of yours. Curious if you ever found the cause and a solution? I have a similar situation as you (2002 C2 Cab. with the M490 audio package). Curious - is the whine ONLY coming from the rear seat speakers? Mine seems to be. I've been trying for a LONG time to fix this, but haven't sadly figured it out. Not sure what the stock radio/head unit was, but the previous owner pulled it, and put and installed a Blaupunkt Beverly Hills 71 unit. I BELIEVE the stock CDR220 radio chassis is making contact to a metal "tab" on the left side of its dash mounting. directly next to THAT metal tab is the grounding wire of which you speak. SO it is POSSIBLE that your new head unit isn't making contact to that grounding tab. I didn't get a chance to test that yet on my end. In my case the "whine" is constant, unchanging with increase or decrease of radio volume, and has no correlation to engine rev. Matter of fact it exists even if only the ignition key is in the "ON" position.
  24. Must not be seeing one of the microswitches (dirty, misaligned, or broken).
  25. OK, fixed the latch / catch not unlocked issue. I had not fully advanced the hook after lining up the dots as I thought I had. Microswitch now engaged, correct result reported. Same result when calibration attempted: nothing, followed by "Function inactive, end position not reached."
  26. My 2001 C2 top has not worked the entire five years I've owned the car, full saga below.* Without all the back story, here's where I am today. When I click "Calibrate," nothing happens and PIWIS 3 returns "Function inactive, end position not reached." The front latch is reset per the service manual, and the clamshell potentiometer was installed at as close to 6.2k ohms as I can get it (about 6.24-6.26). [I rebuilt this engine in my dining room with my cat, 12,000 miles ago—I may not know what I'm doing, but I can follow directions.] Top is in service position. Actual Values / Input Signals Latch locked Catch not locked Latched unlocked Catch not unlocked (can't be both, right, has to be one or the other?) EDIT: RESOLVED, please see follow up post. Convertible top Convertible top raised Convertible top compartment Convertible top compartment lid unlocked Right side flap up Right side flap not up Right side flap down Right side flap down Left side flap up Left Side flap not up Left side flap down Left side flap down Speed Speed >5 km/h (3 mph) (that's not correct) Handbrake Applied Latching hook Latch hook not actuated Engine-compartment lid Engine-compartment lid closed Convertible top button Close convertible top button actuated Supply voltage 14.45 v Warning light on 36044.3 min (!) Actuation counter 1 1746 Actuation counter 2 65536 Calibration counter 2 Pot 1, convertible top 0.92 v Pot 2 (conv. top compartment. lid) 2.51 v Calibration: Pot 1 val 1 0.80 v Calibration: Pot 1 val 2 1.27 v Calibration: Pot 1 val 3 1.88 v Calibration: Pot 1 val 4 2.29 v Calibration: Pot 1 val 5 2.96 v Calibration: Pot 1 val 6 3.22 v Calibration: Pot 2 val 1 1.55 v Calibration: Pot 2 val 2 1.82 v Calibration: Pot 2 val 3 2.00 Calibration: Pot 2 val 4 2.71 These aren't even actual calibration values, are they, they're stored values from the last time it successfully calibrated. It's my latch isn't it. There's a microswitch I've overlooked, a stupid simple on off switch, and because of that, it never starts the calibration process. Guess I'm going out there one more time this weekend and taking that off again. Insight invited, thanks for letting me ramble. 😄 Keith *The Complete Saga I bought the car like this in January of 2001. Tip cab with a top that had been manually put up via emergency procedure. Dash light for the top was on. I found a matching hardtop an hour away that same week, manually put the top down, slapped the hardtop on, and drove it. Turns out, the left rear window regulator had failed and someone had manually pulled it up (the motor was missing) and then drove a drywall screw through the regulator frame close enough under the bottom of the window bracket that the window stayed up. I rebuilt both rear window regulators and in October of 2021, started working on the top. I probably didn't reset the latch correctly at that time, or the clamshell pot. Still, I told Durametric to calibrate and it started to. When the top moved doubt 1/2 way up, I could hear the pump motor straining and—since the rear interior panels were still off—I took a look: both hydraulic pistons were jetting fluid down the rain drains. I put the hard top back on. Then the engine failed, then (unrelated) I moved, and I spent all of 2023 rebuilding it. July, 2024, I sent two cores to Cab Hydraulics in Sarasota to rebuild. Put them in, new hoses too, and this time I reset the latch and the clamshell pot correctly. I think. But there was no longer a top warning light on on the cluster. I told Durametric to calibrate it, and it wouldn't. Opened a dialogue with the developers, sent them logs they asked for, did everything the guy said, and the last I heard was that maybe their software wouldn't calibrate it unless it was in an error state. Then (not their fault) I took a job and started the process of moving. Hard top went back on. July 2026, time to get back to it. I knew I was going to have to have access to PIWIS, so I followed that thread on some other forum ("under $75") and got the image running on my shop computer. Which, I understand, isn't the same as pulling up to the dealer, so I'm aware that's a possible failure point. I 100% believe the latch and clamshell pot to be correctly reset now. No dash light. When I click "Calibrate," nothing happens and PIWIS 3 returns "Function inactive, end position not reached."
  1. Load more activity
