I need to remove my tiptronic knob from the lever because I have to take out the center console. Only not sure on how to remove the knob?
Could somebody please explain me the procedure?
Thanks, frank
Removing selector knob
Note: The ignition key must be in position 1 before the locking button can be pressed.
1. Press locking button and release lug under the locking button in direction of travel using an Allen key, for example.
2. Pull off locking button against the direction of travel.
3. Use a screwdriver to lever the spring clip out of the lock.
4. Pull selector knob up and off the selector lever.
Installing selector knob
1. Push spring clip all the way back.
2. Fit locking button.
3. Push complete selector knob over the lock and all the way onto the selector lever.
Hi Loren,
Thanks for the pics. This should work (not quite sure about the removal of the first part: removal of the button).
Do you perhaps have the same of the removal of the center part (where the handbrake is, not the PCM part)?
Thank, frank
Hi Loren,
Thank, frank
The B&M short shifter instructions cover the console removal. They are actually pretty good.
Just go to their site and download the PDF file.
  • 4 years later...
