Motronic Fault Code Durametric
Just done my first Durametric analysis of my new car and just wondering if any of these codes are easy to fix myself DIY or just let the guy know for my next service?
Its a 2000 Model due for its 80,000kms service and I've found someone who can actually replace the spark plugs. I will also have to get the oil changes at least every 6 months as I purchased a 3 year warranty so wondering what you guys think about using synthetic or Mobil 1 as oil. I drive about 5000kms per year and the trip to the office is only 1km.
It's only been a week of ownership and all seems well with this car. Will be selling my SLK after the first service for my Boxster, though I might miss the folding hard roof :D
P0107 Ambient Pressure Sensor – Below Limit
Possible cause: Short circuit to ground
P1126 Oxygen Sensing Adaptation, Lower Load Range, Bank 1 – Below Limit
P1133 Oxygen Sensing Adaptation, Lower Load Range, Bank 2 – Below Limit
Possible causes:
– Incorrect signal from MAF sensor
– Fuel pressure too high
– Fuel injector fouled
In most cases this is a bad MAF sensor.
P1128 Oxygen Sensing Adaptation, Idle Range, Bank 1 – Below Limit
P1130 Oxygen Sensing Adaptation, Idle Range, Bank 2 – Below Limit
Possible causes:
– Fuel injector leaking
– EVAP canister purge valve open
Again start with the MAF.
Glad you bought the Durametric but anyone can change the plugs, it's rather simple. If you got the money for someone else to do it go for it...but if you bought the Durametric I figured you may be a DIY'r!
As far as the oil you may want to check with them. You need quite a bit of mobile 1 and you are doing it way more often then Porsche recommends...and if you read the owners manual I believe it only tells you to use Synthetic.
Thanks for that report on my fault codes, I will start with the MAF, are any of these faults urgent and what do they effect?
With regards to the warranty, it's through Fortron an after market thing and I agree servicing every 6 months is very old school but if I dont do it im sure they wont pay for any claims!
the warranty doesn't cover the MAF?
I am guessing they wont cover parts that need to be replaced under scheduled servicing, but I will
ask when I get the service including spark plugs which I booked in for next week :D
Going in for service this Wed, fingers crossed I dont get the call for additional work,
though I've booked in for Gold Class to see the new Batman flik so good luck with that!
  • 3 months later...
Possible causes:
Possible causes:
I got the first service done and gave them a copy of this report a week before it was booked in, however they didnt really seem interested in replacing the MAF. I got no report on it either when I got it back, the car seems to run fine. How do you know when you really need to replace the MAP, does the car run ruff or something?
