Can anyone tell me where its at and how to access it? I'd like to check it for cracks or an open purge valve. Thanks!
The actual canister/tank/filter whatever you want to call it is located in the passenger front wheel well, just behind the wheel. If you have evap faults though a common cause for that is the purge valve getting stuck (11 in that picture above. You'll find it in your engine compartment with a hose coming off each end and an electrical connection.
