Leaderboard
Popular Content
Showing content with the highest reputation on 01/08/2023 in all areas
  1. I had the unit installed a week ago. Brilliant sound especially compared to the CDR23. A friend thought I got new speakers or a bass box. It really wakes up the existing Bose speakers. My rear view mirror pulses with the beat there’s so much bass. Notes: volume seems a bit limited. The top number for the volume control is 30. Between 20 and 30 it doesn’t get much louder. Don’t get me wrong it’s crystal clear it just lacks that final umph of volume on some songs. I’m noticing that some songs are plenty loud and some songs not as much. There may be some “clipping” of digital audio. You can adjust individual source audio levels in the volume menu to add or subtract 5 steps to UsB or tuner or IPhone. Come to think of it I should experiment with an android phone to see if it has the same sound limitation. I was curious about the CAN versus AMP setting. I have a 2003 with the MOST system. I made the switch from CAN to AMP on the theory that this was my route the sound through my trunk mounted amp and increase the volume. I’m not sure if it made a difference, but it did turn off my air-conditioning compressor. Then, after turning the car on and off, the air-conditioning and the unit was off all together until I switched it back to the CAN setting. All in all I think the unit was completely worth it $1850 installed in LA County Southern California. My installer didn’t have any drama, which is why I went with someone experience. I am pretty good at DIY but was glad to use someone who had all the trim pieces at hand and easily routed the antenna up under the right dash speaker to the A pillar. This upgrade really improves the driving experience of the whole car. As my son said “you don’t need to get a newer car now.”
    1 point
