Leaderboard
Popular Content
Showing content with the highest reputation on 01/06/2024 in all areas
  1. right new unit fitted today and all solved and for all your guys help on here i will give something back and tell you how to fit the unit and diagnosis . put car in neautral and remove earth on battery ,remove gear knob (silver button pops off , remove clip , slide knob off ) remove J-gate surround very tough clips use a trim tool start from the back BUT be carefull to note which way round the cover goes under this on the bottom of the stalk to cover the hole when shifting , other wise upon refit it will cause you pain not knowing how it fits wasting time working it out because it jams between TIP and Auto when switching between remove ash tray and torx screws under and un-plug light in cubby hole remove rubber matt , undo torx screw remove plastic panel and undo two torx screws under there remove handbrake side trim pops off remove trim (mine was carbon fibre panel ) just above where gear knob was under radio as such remove other relevant screws recline seats fully and remove centre console unit , on passengers side locate white MFS box and remove plugs (reverse light plug very hard to get out !) bridge out plug to confirm your fault (after reconnecting battery Now either replace the unit and OR open up unit and you will see the metal contacts will have come away from the copper strip and so just bend down to make contact again and test ,. now fit the unit back this is why you left the car in neautral , the new switch has a locking pin inside it to keep it in neautral , fit new switch and plug in , reconnect battery and turn ignition on making sure the car has been left in neautral the whole time or it forgets where park is ! now rebuild your centre console 2-3 hours max . that is my rough guide hope it helps someone else !
    1 point
  2. any ideas on what the pin is for ?
    1 point
  3. Anyone know which part of this is the reverse light switch ? I have the new MFS unit (white bit ) but want to test the old one first by bridging out the connector first to confirm my thoughts , i think its the blue/black small 2pin plug at the bottom or is it the brown bit on the top ?
    1 point
