Leaderboard
Popular Content
Showing content with the highest reputation on 08/02/2024 in all areas
  1. Managed to get all 12 (I was mistaken on the number earlier). A few important notes for anybody attempting to tackle this. 1) USE REALLY HIGH QUALITY DRILL BITS! If a bit breaks in the head, you’re far f***ed 2) Use tons of cutting grease/fluid after every 10 seconds or so of drilling to keep bit tip cool and lubed. Make sure not to strain harden bolt going as fast as you can. Take your time and clear chips out of flutes often. 3) DRILL AS PERFECTLY STRAIGHT AS HUMANLY POSSIBLE. Can’t stress this enough. If it’s not straight you will drill the bolt and the head out. When you go to tap, you may dislodge the remaining broken bolt piece. This will cause tap to seize up and hole to be ruined. Then you’ll have to go over size with helicoil 4) You will need extended (6” long) drill bits in sizes 3/16, 1/8, 1/4 and 17/64 (or letter J 7mm). Drill but stops help too. DONT DRILL PAST THE BOLT OR YOU ARE IN THE WATER JACKET! I drilled in steps. Smallest to largest. Smallest pilot hole through center. About 20mm of thread engagement to drill through and a 3mm air gap in between end of bolt and head so when you get through you’ll feel it. Don’t keep going! 5) You will have to remove the thermostat and drain the coolant in order to be able to drill that last one on drivers side straight on. The thermostat housing eclipses the bolt by like 1/4”. Also, undoing the mounting for the coolant tube helped make room for drill head. 6) Stainless hardware or very high grade hardware and nickel anti-seize will last forever. I also used a torch and an air hammer to heat up and remove all 6 manifold collector studs and replaced with grade 10.9 bolts and nuts. 7) Have a face shield and long sleeves because it will be raining hot molten metal chips down in your face for 3 days straight 8 If you have the funds I highly suggest stromski racings drill guide kit but it is pricey for a one time use item 9) when tapping use grease, check x and y to make sure you’re staying straight, remove and clear chips out of flutes often and use the 3 turns forward 1/2 turn back method 10) vacuum fill the cooling system or fight bleeding
    1 point
