  1. A good set of metric wrenches and sockets (10mm to 19 mm). A set of smaller Torx drivers (10, 15, 20, 25, 30, 35). A good torque wrench (that has not been dropped) (0 to 150 ftlb). An average torque wrench for wheel bolts only (0 to 150 ftlb). A good jack and a hockey puck ( to protect the underside when lifting the car). Jack stands and/or sturdy ramps. If you have a laptop computer then the Durametric Software for OBD II diagnosis and fault code resetting. Those seem like a good start to me... :D
  2. Porsche makes VW bid it hopes market refuses
  3. CDR-23 and newer radios do not have codes to enter. The radios are matched in the DME - so if you change radios you will need a shop with a PST2 or PIWIS tester.
  4. The parts list has 955.552.247.01.A03 as the non-smoker package (available only in black).
  5. 18" is the largest listed in the Porsche parts list.
  6. Here it is reduced in size... Idle_Control_Valve___cleaning_98_boxster_2.pdf
  7. It should - the only things that changed were the leather colors and the Porsche logo (slight).
  8. To my knowledge there has never been a Porsche Sport Exhaust for the 996TT (including X50 packages). All the "sport exhausts" I know of for 996TT are aftermarket.
  9. They all worked for me. Did you remove the spaces? (i.e. PNA50398701)
  10. It is the same part number (996.618.980.03).
  11. Folks - please just keep it civil here and keep it on topic. Everyone is entitled to their opinion...
  12. From everything I have heard (to date) the 997 seal is your best choice.
  13. Water in the brake booster?
  14. If it is up (all the time) then chances are there is air in the system. It is just a bleed valve and Cup Car racers leave it up most of the time.
  15. Offset Explained - check out this link http://www.renntech.org/forums/index.php?a...DE=02&cat=4
  16. That is okay - and welcome! With over 54,000 posts here many topics have been covered in a great deal of detail... enjoy! :welcome:
  17. That will depend on the wheel offset. Email the seller and ask them for the wheel offsets -- then we can help.
  18. Have you done a search here? These same faults have been discussed many times here before. Just search for p1128 and p1130.
  19. PCA has an "Excellent" comparison (IMHO). Much more detail and testing than I have ever seen (other than pure racing teams).
  20. Only if they will let you put the locking assembly in (at their location since you can't drive it until the keys are programmed). I would buy a spare key from Sunset Imports (Porsche Parts at Dealer Cost at the top of any page). That way if their are any questions about the authenticity of the key - you have a Porsche dealer to vouch for it and you.
  21. Yes, the key info (transponder data) will need to be transfered using a PST2 or PIWIS tester.
  22. If your battery is 4 year old (or older) then it likely needs replaced. Many auto parts stores will load test and specific gravity test your battery for free. If you had other electrical problems I would look at the ignition switch - but the battery is the beat place to start.
  23. :welcome:
  24. As they say in their ad - "the rears will require spacers for C4S".
