  1. Put the filter back on the car and then tap it off (carefully) with a hammer.
  2. No they are not SS braided. SS braided lines need to be tightened often as they are stiffer and they tend to unscrew themselves when trying to flex. Good for race cars that are checked and retightened every race but not such a good idea for street cars. IMHO of course...
  3. Way too new to have pad or rotor issues. I wounder if the power assist has a problem or like Don said a leak in the hydraulic system. A leak doesn't necessarily mean fluid coming out. It could be the master cylinder is not holding pressure.
  4. Based on the cars age and mileage I would have them look/change the brake fluid, pads and perhaps rotors. Really need some history of the car to make a better guess.
  5. If the previous owner wired it correctly then all you should need is a new switch. Just reroute the wires to the new switch.
  6. IMHO I think you were over-charged. To do a RMS you need to drop the tranny and I know they can do that in under 2 hours. There is no difference - just installing a different transmission and a test drive.
  7. Yes loosen and move the horseshoe piece. The easiest method is to use a butter knife under the bottom edge with a soft cloth to protect the leather and CF. You do not need to remove any switches - just let it dangle. Then press in on the spring clamps and pull the PCM unit until you can see connectors.
  8. Remove the two dash switch side pieces (with the switches but not part of the PCM I). On the side of the PCM unit there are spring clamps. Push those in to release the PCM I unit and pull straight out.
  9. I have the factory TSB if you need it... PM me with your email address if you want a copy.
  10. Try Sunset Porsche. I paid under $7 when I bought mine.
  11. It is about a 5-8 hour job depending on your experience level. You will need a spring compressor and a lower balljoint puller. If this is something you really want to tackle let me know and I can provide more info. Also, remember you will need to get the car re-aligned immediately after. Changing the springs alters the ride height which also alters camber.
  12. I would expect labor to be 3 hours or less. I believe the retail price for MY99 6 speed w/o LSD or TC is about $9000.
  13. That is the part number I gave above.
  14. 996 552 025 01 ETQ is for the the black leather surround that goes over the instruments. It will fit all cars to MY02 (old gauges). If you want one for the newer gauge set then it ends in 02 ETQ.
  15. Pull very very slowly... and try pulling at the normal (release) angle. I haven't quite figured out the trick but they usually do release.
  16. Aerokit Cup (early) or Aerokit II? They are quite different procedures. Bumper R&R is covered in my Third Radiator DIY here
  17. The only thing that I know is different is that when you align and corner balance the car you put the drivers weight (in weights) in the right seat instead of the left ;)
  18. Jeff is correct. This is true for Carrera's also. As of MY99 (through MY04) those are the 4 options. These settings can only be changed by a shop with a PST2.
  19. Cosmoline is a brown colored anti-corrosion spray that covers the underside of the car (for the trip over on the boat). Many times it can get on the exhaust or other parts where it smells when hot. Cosomoline will not hurt anything and does not need to be removed, It doesn't smell exactly like oil more like a waxy odor.
  20. Do they look like this? If, so the part number 996 563 421 01 US retail price is 2.32 USD each and you need 2 of them. (image courtesy of Scouser)
  21. Pat, Well, if you are sure it is oil and not cosmoline then I would look at the valve covers. A few have been known to leak (but not nearly as bad as the 70's and 80's 911's ;) ).
  22. I have used that many times with no problem. I usually jack the rear up that way - put the jack stands in place - then do the work.
  23. Yes, a little. I installed mine (B&M Short Shifter) in 2000 and it has loosened some since then. Yet it is not too loose.
