  1. Really? I gave that to you last year. Perhaps you should write it down this time.
  2. Fault 34 -- Passenger compartment monitoring sensor - Short circuit to B+ or faulty
  3. I sent you a PM.
  4. The airbag fault code should tell you which device (driver or passenger buckle, or control unit.
  5. Try 7626
  6. Try 5060
  7. Try 4685
  8. Could be a bad electrical connection in the buckle. Fairly common - more so as these cars age.
  9. You did not read the Lost Radio Code FAQ... "CDR-23 (or later):These radios do not have a security code - that is, not that the user enters.These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  10. One beep means you have one or more alarm zones open. Two beeps means you have an alarm system fault. Durametric or PIWIS can immediately identify which zone or component has failed. Without the diagnostic everything is just expensive guesses.
  11. It is always best if you tell us the exact model and year of your car.
  12. I'm pretty tied up until the second week of April - so perhaps someone else is free before then.
  13. This site does not distribute copyrighted materials. WKD 951 020 07 PCM 2 Manual -- US MSRP $17.45 at your local dealer.
  14. Did you try looking here?
  15. Sounds like someone has bypassed the clutch switch. Look for a jumper or perhaps someone tie wrapped the switch to always open.
  16. It is always best if you can give folks your car's exact model and year.
  17. You need to re-train the windows. Hold the Down button until the window is all the way down - then hold it for 10 more seconds. Do the same for window up and you are done. One-touch should work again.
  18. Try 4673
  19. Try 2893
  20. If you read the Lost Radio Code FAQ before posting here you would see what radios are supported here.
  21. Try 4341
  22. Try 4709
  23. Try 6590
  24. Try 9654
