  1. Sorry, I can only decode Becker - Porsche radios.
  2. Try 4546
  3. Try 7401
  4. Try 7543
  5. I have a MY99 Carrera - 6 speed and this is what I use: Engine oil / maker - Mobil1 0W-40 or 5W-40 Oil filter / maker - Porsche factory Transaxle oil / maker - Mobil (Mobilube PTX) 75W-90 Spark plug / maker - Beru or Bosch 14FRG 6KQU The one I would caution you on is the transmission/transaxle oil - lots of issue with non-Porsche recommended brands. I would definitely stick with Porsche approved transmission/transaxle oils.
  6. Try 0592
  7. Do a search here... likely ballast resistor or relay.
  8. Try 7543
  9. Try 4210
  10. That shutoff valve should be in the lines (more or less as shown) behind the wheel well liner.
  11. On a Model Year 1998 I'm pretty sure it is on the carbon canister.
  12. For 6 preset Traffic Pro... Try 52231
  13. Try 9095
  14. Try 8354
  15. Try 5190
  16. From the Lost Radio Code FAQ... " Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/ OPC. "
  17. According to Porsche's parts list it is not sold separately - so your best bet is a salvage yard.
  18. Exact model and year of your car please?
  19. READ the Lost Radio Code FAQ This topic is now closed
  20. All the (factory) knobs I have seen for 6 speeds are one of two types. One type is just push on and off. It has a sleeve that gets worn. The other type has a single hex setscrew at the base of the knob to hold it tight on the flat of the shifter. This often can come loose and I usually put a little Loctite on the setscrew to keep it from vibrating loose again.
  21. Exact model and year of your car please?
