  1. Try 2752
  2. Somebody didn't read the Lost Radio Code FAQ... "I get a WAIT on the display - what do I do? You have to wait at least 30 minutes before trying again."
  3. Try 0586
  4. From what I can see in the photo it appears to be the oiled filter.
  5. Try 4862
  6. A double beep means that there is an alarm fault that can not be reset. You need to read the fault codes for the alarm system to location the problem sensor or control box.
  7. Try 6576
  8. Try 4593
  9. Try 7173
  10. You did not read the Lost Radio Code FAQ "Which radios fitted to Porsche can have their unlock code recovered through serial number? - CR-220/CDR-220 - Becker - CR-210/CDR-210 - Becker - Traffic Pro NAV/CD - Becker"
  11. Before the 17 digit VIN numbers there was little information that could be gleaned from the VIN. Sorry.
  12. Try 4928
  13. Have you used a Porsche specific scanner to get fault codes? If so, please list them here.
  14. Try 4916
  15. Try 5195
  16. Try 4612
  17. Try 3031
  18. You might want to check that your Durametric is up to date with revisions. Also, it could be a bug in the software - but the only way to tell might be using a PIWIS tester.
  19. From the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  20. Many times control unit issues can be fixed by re- programming that module. If that does not work then a new control unit will need to be installed and programmed to your car.
  21. Try 6951
  22. Try 0876
  23. Try 5210
