  1. Give your dealer/OPC your VIN and they can tell you which key fob can be programmed to your car.
  2. From the Lost Radio Code FAQ... "Which radios fitted to Porsche can have their unlock code recovered through serial number? - CR-220/CDR-220 - Becker - CR-210/CDR-210 - Becker - Traffic Pro NAV/CD - Becker"
  3. Try 8356
  4. Try 0709
  5. From the Lost Radio Code FAQ... "Which radios fitted to Porsche can have their unlock code recovered through serial number? - CR-220/CDR-220 - Becker - CR-210/CDR-210 - Becker - Traffic Pro NAV/CD - Becker"
  6. Try 0565
  7. Try 4718
  8. Try 5193 and Try 1312
  9. Try 0758
  10. Try 1549
  11. Only to the extent that both signals go to the instrument cluster. Both are just warnings spoiler extended light or ABS activated light. I would treat as separate issues.
  12. Try 0987
  13. Sometimes you can get an ABS error from wheel slip - either from wet pavement or loose gravel. In those cases it usually clears itself. Also, if your battery is 4 years old or older it should likely be replaced - a weak battery can cause all kinds if anomalies in these cars.
  14. Try 1025
  15. Try 3292
  16. No, the only place you can get a PCM codes is from a dealer/OPC.
  17. From the Lost Radio Code FAQ... "These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM codes is from a dealer/OPC."
  18. Try 1215
  19. Try 9024
  20. These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM codes is from a dealer/OPC.
  21. You will need a PIWIS tester to copy the program/codes from your old KESSY/PAS to your new one.
  22. Try 9121
  23. Try 0217
  24. You can carefully pull the cluster and reseat all of the cables making sure they are all locked in place.
