37,301 -
Days Won
530
Posts posted by Loren
13 minutes ago, jim_hoyland said:
Question: do rotors have their thickness stamped onto the rotor ?
Not that I recall.
39 minutes ago, slav said:
Hey there, just woke up my 2002 996 after a long hibernation. I have no code on hand (have never needed it before).
Becker CDR-220
Model No. BE 4482 (I think, as some of the pixels are out)
Serial No. 15007779
Thank you so much!
Try 4895
- 1
31 minutes ago, Alan Boo said:
Hi,
Just got my 996 ME, previous owner lost the radio code
Becker CDR-220
Model No. BE 4462
Serial No. X5032312
Thanks.
Try 6453
- 1
22 minutes ago, Novice Boxster Owner said:
I plan to replace my 1998 Boxster instrument cluster with a used one I get from EBay. Does anyone know if the mileage on my current cluster carries over and will appear on the replacement cluster or if the mileage on the replacement cluster will appear?
Check with your state laws - here in California you need to document your current mileage and the mileage on the replacement. It is intended to show the car's true mileage when re-sold. So, no the mileage does not transfer over (legally).
- 1
25 minutes ago, Starsmark said:
Need codes please!
x5017045
4462
48/98
99 boxster
Try 5135
- 1
The part number is correct. 6 screws per car (3 per side).
- 1
55 minutes ago, CabrioArtie said:
Loren,
New radio for my car, but need the code.
Model - CDR-220, BE4462
Serial - 15075092
Thank you,
Artie
Try 9475
6 hours ago, Allen Chipley said:
Bought replacement radio for my 2003 Porsche Boxster on Ebay and need the radio code. Model #BE6612, serial #35051265. Thank you!
From the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios do not have a security code - that is, not that the user enters.
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected." -
1 hour ago, Galaxy said:
Need some help getting a radio code. My family has a 2001 Boxter S and we disconnect the battery every winter for storage and the radio has been asking for a code for a while now.
Becker CDR-220
Model No. BE 4462
Serial No. 15086165
Try 0684
2 hours ago, alex222 said:
Did you read my Q?
Did you see the diagram? That is the correct orientation. In your photo you have the shield upside down.
#1 cause is the clutch microswitch.
3 hours ago, SBA704 said:
Hello I need some help in finding my radio code .
2002 Carrera C2
CDR-220 model BE-4462
serial no X5026285
Thanks so much!
Try 9812
- 1
All of the lights including the hazards go through the front end control unit. Chances are that either it took a spike or otherwise lost some of it's programming. A shop with a PIWIS tester should be able to try and re-program that module.
The PSM warning is normal with a battery change and as you saw self correcting.
7 hours ago, Anandan Subramaniam said:
Hi Can you help provide code for
Model number BE 2580
Serial number 65151489
From the Lost Radio FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC." -
1 hour ago, Not_James said:
Good evening, just revived from a dead battery in my 996.
CDR-220
Serial # - Y5022282
Type: 4362
24/99
Thank you!
Try 2629
28 minutes ago, Merv the swerve said:
Hi Loren,
A pleasure to connect with you. I've read your responses on this forum many times. Thanks for your efforts for Boxster owners. Are you the same Loren as used to run monster 911's in POC 15 years ago?
Sorry, no. The only thing I did with POC was the annual Make a Wish ride alongs at Laguna Seca.
8 hours ago, Dana_k said:
Good morning. Could please anyone help me with the code of a Becker radio?
model : BE 7045
Serial No : 78039394
thank you !
That is not a Porsche radio - so this may not work.
Try 9618
10 hours ago, KRacer said:
CDR-220
Type 4462
24/99
SER 25016809
Try 8909
- 1
3 hours ago, DaveAir said:
Type 4462
ser# X5023763
48/98
Try 8607
I would also look at these in order of known failures...
- ignition switch
- wet/damaged immobilizer control unit (under the drivers seat)
- positive lead from battery to starter/starter solenoid
- crankshaft position sensor (can usually be found with a Porsche specific scan tool).
41 minutes ago, Ishandhawan said:
Hi there!
Recently bought a 2000 Porsche Boxster S without any manual and need the radio code.
CDR-220
Serial # - X5032962
Type: 4462
48/98
If you need anymore information, let me know! Thanks again!
Try 4727
Lost Radio Code - post your request here
in Lost Radio Codes
Try 4949
