37,306 -
Days Won
530
Posts posted by Loren
10 hours ago, KRacer said:
CDR-220
Type 4462
24/99
SER 25016809
Try 8909
- 1
3 hours ago, DaveAir said:
Type 4462
ser# X5023763
48/98
Try 8607
I would also look at these in order of known failures...
- ignition switch
- wet/damaged immobilizer control unit (under the drivers seat)
- positive lead from battery to starter/starter solenoid
- crankshaft position sensor (can usually be found with a Porsche specific scan tool).
41 minutes ago, Ishandhawan said:
Hi there!
Recently bought a 2000 Porsche Boxster S without any manual and need the radio code.
CDR-220
Serial # - X5032962
Type: 4462
48/98
If you need anymore information, let me know! Thanks again!
Try 4727
1 hour ago, Nick Chesshir said:
When we power on the radio it says protect and allows us to click the bottom buttons to enter a code.
But if they talk over the fiber bus it seems something isn’t working being there is a fiber signal out of the stereo but not into the stereo.
I guess it’ll be time to retire it and get something more modern.
thanks for the help
From the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios do not have a security code - that is, not that the user enters.
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected." -
9 hours ago, Nick Chesshir said:
Hello,
Just got my wife a 04 Cayenne S and needs a radio code and had no manuals.
Typ: CDR-23
Model No: BE 6627
Serial No: 35005451
"CDR-23 (or later):
If you look at my third radiator install DIY the first part deals with front bumper removal.
Perhaps a pending fault since it is intermittent.
Don't forget about the crankshaft position sensor.
Lost Radio Codes
DO NOT START A NEW TOPIC FOR A LOST RADIO CODE. DO NOT EMAIL ADMINS.
Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread. -
Left Front sensor -- 997 612 755 01 sender wire (pad wear indicator) US MSRP $59.28
Right Front sensor -- 997 612 757 01 sender wire (pad wear indicator) US MSRP $59.13
Sensors include cable and connectors... item 7
Rear (same for both sides) -- 987 612 676 02 sender wire (pad wear indicator) US MSRP $35.64
You can get better Porsche parts pricing through Sunset Porsche (board sponsor):
Factory Porsche Parts, Tequipment and Selection (Boutique)Genuine OEM Porsche Parts | sunsetporscheparts.com | Sunset Porsche Parts
WWW.SUNSETPORSCHEPARTS.COM
Find genuine OEM Porsche Parts direct from sunsetporscheparts.com at unbeatable prices. Also find Porsche Drivers Selection gear and accessories. Shop Securely Now. -
14 minutes ago, Matt Fussell said:
This thread is awesome! I need some help with my radio. The model is BE 2582. Serial number Y5007985.
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC." -
There are several brake options, different size rotors, etc., including ceramic rotors.
PM me your VIN and I will lookup which fit your brakes.
1 hour ago, Drhancur said:
I need a radio code for BE4462, serial number: Y5043167. Thanks.
Try 4350
What scanner did you use - that is not a Porsche fault code.
1 hour ago, villet said:
Hello,
I've got the same old story. My radio:
- CR-220
- Model: 4367
- Serial: X5018812
Any help would be much appreciated! 🙂
Try 5473
- 1
20 minutes ago, Tintin14 said:
Hi, I need help retrieving a code for Becker CR22 BE4367 Y5022055, any suggestions would be greatly appreciated
Try 1060
- 1
42 minutes ago, his15153 said:
Hi,
I'm hoping to get a lost radio code for my CDR -210 SN W5023523 from my 1999 996.
Try 8704
27 minutes ago, jim_hoyland said:
OK; I just had some 70K service done on my 2006 987, no problem.
But, in the recommendations box it says to replace the fuel pump and filter.
IDont understand how that could be recommended on an excellent running. 987 !
any thoughts ?
Your fuel pump and filter are inside the gas tank.
I would not go in there unless you are having problems. It's easy enough to measure the fuel flow should a potential problem arise.
As long as thay are the "big tube" design they will work on any 996 (as shown on Carnewal.com).
It is the "small tube" version that Porsche says to use only on 3.4 liter cars.
12 hours ago, vza said:
Do you know if it would effect any HVAC controls if I left in the display with the incorrect graphics.
Sorry, I don't/
Perhaps if your battery is low and it is on a long time. But in most cases it will turn on and slowly charge the battery then turn off until the voltage falls to a certain level. So once established in should only go on about once a week.
Lost Radio Code - post your request here
in Lost Radio Codes
That is not a Porsche radio - so this may not work.
Try 9618
