- Paint Codes
scanner-1
Contributing Members-
74 -
Last visited
Days Won
2
Exterior Paint Colors
Classifieds
Everything posted by scanner-1
2003 Boxster Passenger Door Stuck Closed
scanner-1 replied to Joseph Ek's topic in 986 Series (Boxster, Boxster S)
Did you have a bad wire or connector? I recently tried a cheap door lock actuator on my 2011 Cayenne Turbo. It worked intermittently and gave implausible signal codes so the alarm would not set. It was from a place called excellent-autopart on eBay. They were responsive until I asked for a refund then went comm out. This cheap Chinese part and this vendor is a non-recommend from me. The URO part from Rock Auto that is in there now has been working great--twice the price of the knockoff, but 30-50% less than the Porsche part. -
I was hoping you would get some traction on this question as I have a 2013 CD with 160k and a 2011 CTT with 80k and I am contemplating doing the trans fluid on both. What did you end up doing with yours? Note: I have replaced the transfer case fluid in the CTT 15k ago with Ravenol TF-0870 and it is working well.
So I just replaced THREE (yes 3) rear door lock actuators. To recap: Left rear door exterior handle would not open the door after unlocking with keyfob or by proximity. Right rear door would not lock (and no confirmation beep). Since it was a bigger security issue, I replaced the RR first and decided to experiment by buying the $37 actuator from Hong Kong as found on eBay. The door lock would now physically lock, but the alarm would not set. Occasionally, the exterior handle would not work either. I was unable to clear DTC 000843 Central locking closing unit, implausible signal. Due to my experience with the $37 part, I decided to splurge for the $91 URO Parts actuator for the left side. This part worked perfectly and solved the problem. I then went back to Rock Auto and bought the URO Parts right side actuator (why this one costs $17 more than the left side remains one of those mysteries). The RR door is now working perfectly, all codes reset and alarm confirmation chirps occur when locking. Lessons learned: The screws that clamp the window regulator to the window glass are reverse threaded (at least as viewed from inside the car, the E-Torx end, size E-6). Pay attention to the torque specs here (4.5 ft-lb). If you shear this end off, you will kick yourself and likely spend the next week trying to figure out how to loosen that screw--ask me how I know. Reassembling: in order to reinsert the automatic shade rod, you will have to lift the door panel to the exact level that automatically disengages the upper tweeter connector--a mere 1 inch more of tweeter wire would have made this job almost too easy. I suggest you test the stereo before putting all the trim back on, my diagnostic tool speaker test warned me (an embarrassing number of times) that I had accidentally disengaged that connector! And yes, you will break at least one of these: 955 555 243 00.
A new VVT fixed mine too. I am cheap, so I bought the following from Pelican: Variable Timing Solenoid(2011 Porsche Cayenne Turbo Sport Utility)(m) Part #: 948-105-308-03-M40 $45.25 See if you can tell the difference between cheap and expensive: My arms were not long enough to access from the bottom. I did not remove the wipers and fascia as the manual suggested to access the vacuum pump. My main access was from the top combined with through the right wheel well (removed the wheel, fender liner and slightly bent a heat shield). Tip: only loosen, do not remove the top left screw on the vacuum pump, remove the remaining vacuum pump mounting screws and the pump will back out/twist enough to allow removal/replacement of the VVT. Be prepared for some oil to leak out and ensure the vacuum pump o-rings remain in place . Small tools and a willingness to work by feel/limited visibility are recommended if going this route. Knowing what I know now, this is less than a 2 hour job.
2011 Cayenne Turbo, 85K miles, 3/4 tank fuel Car started normally 4 times/ran flawlessly for about 45 minutes driving during a 2 hour period. After the last 30 minute rest, the car would crank but not start, then intermittently start after a long crank and subsequently stall. An engine reduced power warning would display and continuous check engine light. Eventually engine would not start or not run for longer than a few seconds. I read/reset codes with the following results: P0192 Fuel Rail Pressure Sensor Circuit Low Input reset and did not return P1031 Fuel high pressure sensor stuck at start unable to reset P1024 Fuel high pressure too high after engine off reset and did not return Car still unable to start/maintain idle. After about 1 hour, I returned to the car, reset codes (this time all cleared)--the car started and ran flawlessly! Anybody else have something like this happen? Should I replace the High Pressure Sensor or order and keep one around--are these prone to failure? I'm having a hard time finding a diagram with the HP Sensor for the Turbo engines, is it located under the intake manifold like the non-turbos? If so, is intake manifold removal on the turbo very difficult? Any other things I should be considering?
MY2011 CTT, 83K miles, intermittently rough idle with the following codes: P1372 Valve lift control, bank 1 P1361 Valve lift control, cylinder 2 P1363 Valve lift control, cylinder 3 P1362 Valve lift control, cylinder 4 I suspect the valve lift solenoid. It looks like an easy enough job (which means I have obviously missed something). Quickster2, did you do this yourself? If so, any tips or tricks to pass on? Additional info (or does anybody else see a different diagnosis or suggest other data to pull?): I have no frame of reference for the camshaft deviation numbers, do these differences from between bank 1 and 2 seem odd, normal, or appropriate for this problem? N010_Nominal intake camshaft angle 130.88 degree CRK N020_Actual intake camshaft angle, bank 1 130.88 degree CRK N040_Actual intake camshaft angle, bank 2 130.88 degree CRK N030_Camshaft deviation, bank 1 3.75 degree CRK N050_Camshaft deviation, bank 2 -0.38 degree CRK N080_Camshaft adjustment valve activation, bank 1 8.99 % N090_Camshaft adjustment valve activation, bank 2 8.99 % M005_Engine roughness reference value 65498 us M010_Engine roughness cylinder 1 1024001856 us M020_Engine roughness cylinder 2 1024001856 us M030_Engine roughness cylinder 3 1024001856 us M040_Engine roughness cylinder 4 1024001856 us M050_Engine roughness cylinder 5 9.27 us M060_Engine roughness cylinder 6 19.28 us M070_Engine roughness cylinder 7 14.75 us M080_Engine roughness cylinder 8 14.27 us
I was hoping to avoid pulling the door panels off--thought I read somewhere that it might be tricky with the powered window shades? Av8sky, did you replace the actuators yourself and do you have the powered shades? BTW, when mine does this, the scan tool typically reports: 000843 Central locking unit, implausible signal
I have had the same issue randomly occurring with my 2011 Turbo. Another related issue was the other rear door would not lock and my alarm confirmation tone would not chirp. It seems to be more frequent in cold weather, so I suspect it may be a lubrication issue. Not sure if it was luck or not, but I tried spraying WD40 Dry Lube PTFE into every nook and cranny I could find near a handle or lock, then put a charger on the battery and actuated the locks and door handles multiple (many, many) times. Both issues have improved, but they're not 100%, so if anybody has a suggestion for an easily accessible spot on these locks to shoot some lubricant into, please chime in. Also taking suggestions on what lube!
**Bonus repair** After accomplishing "Vehicle Handover", 2 longstanding issues with my PCM were cured also! 1. When playing music via Bluetooth there would be a dropout on a semi regular interval. and 2. When manually advancing a music track on the USB input, the display would not immediately cycle to the next song--sometimes not until the next song automatically sequenced would the display catch up to the actual song playing. All in all, this turned one problem into three repairs. My recommendation for ANY PCM problem is accomplish the Vehicle Handover.
My 2011 CTT with PCM v2.4.7 had the same issue recently. I messed with it for a couple days, charged battery, checked fuzes, checked/cleared scan codes, removed phone data, removed phones, tried Factory Reset, tried some percussive maintenance, then finally tried the only thing that worked--Vehicle Handover. One day later, up pops your post! I can confirm this works. It is a minor pain to reinput all your settings, but sure beats the continual 2 minute reboot merry go round. Thanks Mattski
Have you eliminated these possibilities from the manual? I know all sorts of things got funky on mine when it had a weak battery. Page: 153 The Auto Start Stop function is available with limited functionality in the following situations, for example: – If the air conditioning or passenger compartment heating is operated at a high setting or if the defrost function is run for long time periods. – If the battery charging condition is low. – On upward or downward slopes. – During internal vehicle test procedures, e.g. automatic engine checks.
Almost definitely a clogged AC evaporator drain--I've had this occur on my 2011 Turbo as well. Loosen the spring clamp holding the rubber drain boot onto the evaporator and be ready for some water as you disconnect the boot from the evaporator. Once the evaporator drains, blow compressed air into the boot and through the firewall--this should free your clog. While you're down there, you might want to change out your cabin air filter--actually, anytime I replace my cabin air filter, I now blow compressed air through the drain as a preventative measure.
Found this while out searching for something completely different. Not sure when Porsche Gen3 TPM started, but this exactly describes the system on my 2011 and 2013. The 3rd generation TPM system operates on the principle of unidirectional communication between the wheel electronics and control unit. This means that the wheel electronics can communicate with the control unit, but the control unit cannot communicate with the wheel electronics. The wheel electronics units send the currently measured tyre pressure, the direction of rotation, the temperature of the air in the tyre and the remaining service life (of the battery) as well as a specific ID from the wheel that is currently turning at specified intervals. The wheel position is learned automatically from the side and axle specifications. The direction of rotation of a wheel is detected by acceleration sensors in the wheel electronics (left/right detection). Axle sensing (front axle/rear axle detection) is performed based on differentiated sound levels between the front and rear axle, where the central antenna is fitted close to one axle (high level). The levels received from the other axle are correspondingly low. The wheel electronics units communicate with the control unit in various modes. Depending on the current mode of a wheel electronics unit, it sends telegrams to the control unit at defined intervals. Normal mode: Normal mode is active while the vehicle is driving (after Burst mode has ended). Sleep mode: Sleep mode is activated as soon as the vehicle remains stationary for longer than 5 minutes. The wheel electronics then send no more telegrams. If the ignition is switched on while the wheel electronics units are in Sleep mode, no tyre pressures are displayed (display in instrument cluster: "-.-"). Tyre pressures are only displayed again when the vehicle is driving (see Burst mode). Burst mode: If the wheel electronics units are in Sleep mode and the vehicle is accelerated to over 25 km/h (15 mph) from stationary, the wheel electronics units switch to Burst mode. The wheel electronics units send their telegrams for 60 seconds at fast intervals. If a new set of wheels is used or wheel electronics units were replaced, the TPM system must be taught. When teaching the TPM system, the control unit stores the wheel IDs of the wheel electronics units and assigns a position to them. New wheel electronics units can be taught by selecting a new set of wheels in the instrument cluster. The system is then in learning mode and re-assigns the wheel IDs that are received. But the system also detects a wheel change if the stored information does not correspond to the information received. The control unit then displays a message on the instrument cluster prompting you to select the newly fitted set of wheels. The wheel electronics units can be taught while the vehicle is driving and while it is stationary. Teaching while driving is recommended. The wheel IDs can also be taught without using the System Tester. The following points must always be observed: Allow an idle time of at least 5 minutes before teaching the wheel IDs (wheel electronics units are then in Sleep mode). Briefly accelerate the vehicle to over 25 km/h (15 mph) in order to teach the wheel IDs (wheel electronics units are then in Burst mode). Then continue driving at any speed (even < 25 km/h or 15 mph) for max. 10 minutes. Teaching was successful if a pressure reading is displayed in the instrument cluster for all wheel positions.
- 19 replies
Is it possible it's just the PSM in combination with driving style (and differing thresholds based on sport/normal)? The brakes on my 2011 CTT are noticeably different depending on how I drive--there was that ONE time I drove nice and easy in normal mode on the way to church, haha! from the manual pg 190: Examples of PSM control operations – Brake system prefilling: The brake system is prepared for possible subsequent emergency braking if the accelerator pedal is released suddenly and quickly. The brake system is prefilled and the brake pads are already applied gently to the brake disks.
That I can't be sure of; however, my wife's 2013 Diesel works the same way--I'm guessing it's Porsche standard.
- 19 replies
No programing required. I just cycled through the appropriate entries in the Tire Pressure section of the Multi-Purpose Display, then after a couple minutes of driving, ops normal.
- 19 replies
About 1 year ago, for my 2011 Turbo, from PartsGeek.com: 2011 Porsche Cayenne TPMS Sensor - UVS2000 HUF Intellisens - $40.74 Working great so far!
- 19 replies
- 1
