RKPorsche
Everything posted by RKPorsche
  1. Any updates on this cbonilla ? did you replace the part and issue resolved ?
  2. Hi, I am a new bee with 2002 Boxster base. I noticed the temperature shows ~200 is this normal for Boxster ?. Usually I find the temperature gauge show the mid value in cars. So I was wondering if my car is getting heated up. What do you think is a normal value ? Took a picture in bright light so the picture didn't come out well. but you can see that the gauge is above 180
  3. Replaced Water Pump and Thermos stat. Found one of the Radiator Fan fuse was blown !!!. So replaced it. So far the vehicle did not stall in the traffic. But noticed the temperature is reaching ~200 in traffic.
  4. I have issue with CR220 on 2002 Porsche Boxster Base, it didn't power on at first so here is the progress I made sofar - Read the blogs/youtube and removed the radio after purchasing the radio removal tool from Walmart (~$6) - Found the fuse behind the radio was blown (10Amp), replaced it with one from local auto store - now the radio is ON but prompting for **CODE**, thanks to Renntech got the code to unlock it - Entered the CODE now the radio seems to be working but NO audio !!! - Looked at the service manual and fuse details since some of the blogs pointed me to fuse box and the fuse for the AMP. - The 7.5Amp fuse was blown on the fuse box ROW D and Number 9 (D9). So while I am waiting for the fuse to arrive (from amazon) I - - had a 15AMP fuse handy and tried to insert it but there was a spar when I tried to do that !!!, guessing a short to the ground some where down the wires. - So started to remove Audio related modules from the front of the trunk. And found two Bose modules one seems to be the AMP big black casing with lot of vent holes. And there is another module don't know what it is. After I disconnected the wiring connectors from these modules I was able to insert the D9 fuse in the fuse box. So I am guessing there is something is wrong with the AMP or the other Bose module. Did you see similar problem ? What are these two modules for ? there 3 connectors going to these two modules. Any ideas on how to fix it or get it repaired (i don't know which one of these two has the issue or short)
  5. My 2002 boxster base Has the following issues - fabric glue came off where the convertible top sticks to the engine cabin. - tore on both side of the rear vinyl window
  6. Exclusively to discuss convertible top the soft top on boxster. - repair including stitching, holes, tears - replacement - mechanical issues - electrical issues
  7. Thank you. It worked !!!
  8. Need code for my 2002 boxster radio CCR 220 Model BE 6624 Serial No 15004432 Thank you RK
