Wusthof
Everything posted by Wusthof
  1. If you are looking for a child seat with a 5 point harness that fits, go with the Diono Radian RXT (or the R120). It will of course be much pricier than a booster. It has a 13 inch base/seat and fits quite nicely. I have mine secured (forward facing) with both the seat belt (with a locking clip installed) and using the rear tether point (under the carpet behind rear seats). I did remove the leather seat to keep it from getting ruined, but left the backrest in place. I see no advantage in my particular application to removing the backrest. There is no advantage because the seat belt anchor point holds the base of the of seat out a few inches from the back of car seat anyway. If the seat belt anchor point had been mounted about 3-4 inches further back, then removing the backrest would then allow an almost flush mounting of the car seat. Alas, one cannot have it all, but this is pretty good!
  2. I did consider a re-upholster, however still more than I would like to spend. Thank you. That was the information I was looking for. I may just look into taking the leather off and having a double stitch run on a patch that is fastened underneath the seam. Would do it to both seats so they match. We'll see.
  3. 1999 996 C2, Savannah beige full leather (baseball stich dash), seats are manual except for the seat back, which is power. My drivers seat recently tore along the center stich/seam. I have located a pair of seats in Savannah beige to match, but I am curious about the different design. Pictures 1 and 2 are of my current seat, and the 3rd picture is the seat I am considering replacing them with. The replacement seats are in relatively good shape with almost no wear on the bolsters - $600. Pretty good deal imo. Can anyone tell me if the seat in picture 3 is essentially the same level of trim or higher? Just from a newer model 996? Believe it may be from a MY 2001, but not sure. Also, if these were from a MY2001-04 would I run into any installation issues? Hardware or electrical connections different? Thanks, Brook
  4. I would also add that if you have ever had work done inside the door panels (e.g. aftermarket speakers) there may be additional points of friction in the panel either because of a larger size speaker that was fitted or because the panels weren't replaced properly and might be pushing the window to the outside of the door.
  5. Sorry to just get back to this post, I did a fire and forget. Yes, all the rear lights on the LEDs work as they should. The LEDs (at least mine) are wired to bypass the rear fog light connection. It was just strange that they still provided the connection for the bulb. On the particular LEDs that I have, the bulb just wasn't needed.
  6. I have not confirmed that the transponder is bad, by swapping it out, but more than likely that's what it is. Was in a rush this morning. I was informed (by a friend) that the valet key likely has a chip in it that allows it to start the car. Still confused how a non-powered chip works fine (in the valet key), but a "powered" chip has decided to fail (theoretically it should work with out power if the valet does). Perhaps it isn't that its failed, just that it isn't mated to the car (being that it can be re-programmed, but a valet key cannot be reprogrammed.) Perhaps I reprogrammed it to my neighbors car...sweet, will look into that this evening. Will swap the guts of the keys this evening to confirm a bad transponder (or one that needs to be reprogrammed). In regards to the inability of the remotes to unlock the doors, yes I did try swapping out the batteries, then the various methods of reprogramming them to the immobilizer/alarm system (i.e. unlocking doors, key in ignition, holding button for a couple seconds etc) I also replaced the battery in the non-working key again this morning.
  7. With regards to a 1999 996 C2... This morning my wife "inadvertantly" took my keys to work with her. I grabbed my spare remote key, and to my surprise the dash would light up, but the car would not start. So I grabbed the valet key, and the car started. Just curious as to why this is the case. The battery was good in the remote key. What is the reason for this? I am sure it's related to anti-theft, but don't understand it. On a possibly related note, both key fobs stopped opening the doors probably 2 years ago, so I have been using the door lock since that time, but have only been using one key for that period. I have tried all the described methods for re-mating the keys to the anti-theft module with no dice. So I just decided to live with it, vice spending $100s to get new keys or key heads. Please enlighten me...thanks.
  8. Just a quick note to highlight a common problem with the standard eBay LED Tail Light for the 996, which various vendors sell and not a single vendor (that I could find) informs customers of this issue. The side marker connection (rear fog lamp) in the tail light assy does not need to be hooked up. This is the small connection on the outside edge of the assy. The rear side markers (rear fog lights) will function normally without using this connection. Hooking up this connection will blow the 7.5A rear fog light fuse in fuse location A4. I purchased my lights from voltexinc, because their price was cheaper than others selling what appears to be the exact same Taiwan manufactured light assy. After researching a couple forums, some reported problems with the "hyper" flash turn signals. I can report that this no longer appears to be a problem requiring a resistor to remedy. All other aspects of the assy were plug and play. HTH, Brook
  9. While the thread is asking about original engine, figured I would post anyway. Original engine on my '99 996 had 76,000 on it when I replaced it with a reman, I have since put 66,000 on the re-manufactured engine. 142,000 on the car, with original transmission and clutch, but will soon have to replace those. Its been a fun daily driver for the last 7 years. Would love to upgrade but my mechanic tells me I am married to the car since I replaced the engine. He is probably right, as it appears that it has plenty of years left in it at this point. Recently replaced the struts/shocks and strut arms. The control arms need replacing as well, but haven't gotten to them yet. Still haven't had to mess with the RMS.
  10. Thanks guys, I found a great shop that has about 5 Hunter systems. They will definitely be able to tell me whats going on. Just need to find some time to get the car into the shop.
  11. Is Road Force balancing a part of the Hunter balancing system I have read about in some of the forums? If there is an issue with wear in the steering rack is this something that I should have an authorized dealer take a look at? Or could a decent alignment shop perform these kind of repairs? So far I haven't ventured far from Porsche maintenance, as I am afraid anyone else would screw something up.
  12. 1999 996 Carrera 2 My car's steering feels quite loose at high speeds, and I feel a slight bit of vibrations up front as well. Believe the vibration is tire balance related but don't believe that has anything to do with the loose steering. Would loose steering be related to alignment or something else??
  13. 1999 996 Carrera 2 I recently purchase the luggage rack for my 996, but upon trying to install it have discovered that the bolts are corroded in to the roof. I believe my only option will be to retap the holes. Any one have any thoughts on this? My concern is what if the holes are not retapped at the correct angle. I am not sure how easy this is to do, and would hate for a machinist to screw it up. Anyone have experience with this??
  14. 1999 996. The car has been in storage for the last 6 months. My buddy was supposed to be starting it periodically but let it sit to long. The battery is apparently dead now. I will probably just have him replace that, but does anyone have any guidance on entering the radio/engine code. I seem to remember that if the battery dies a code needs to be entered into the radio. Is that just to make the radio work again, or will the car be disabled as well if the code isnt entered?
  15. Total repairs for engine replace, flushing the radiator, hoses, aluminum tubes, etc...$13,290.00 Donations can be sent to The Wusthof Porsche Fund ;)
  16. The car had 70,000 miles on it. I purchased it with 62,000 from an independent car dealer, so no warranty. It had just had its 60,000 mile maintenance prior to my purchase, and had all previous regularly scheduled maintenance. The tell tale signs for such a problem as fluid mixture is smoke from the pipes and low coolent level and oil indicator lights. I didnt have any of these warnings. It was a 105 degrees where I was driving and the engine temp was about at its highest around 240 degrees, but when I turned the AC off it dropped back down to the 200 range. I believe that I only drove in this condition for about an hour. I noticed a rattling sound at low rpm at a stop light, but the car was still running. Right now the car is not at my local Porsche shop, so I am moving it tomorrow to the local shop. They believe that I will have a case for "goodwill" since I have been a regular customer at the local shop. So Porsche may actually cover some of the cost. The local Porsche shop also indicated that it may not need to have the radiator replaced, instead just flushed a bunch of times, depending on the severity. So I think I might have a little more luck with lowering the cost of repairs, but we will see. The engine will most likely be replaced. The cost of the rebuilt engine alone is $6,767.
  17. 1999 996/C2 Any thoughts on this one??? The oil and coolent were mixing in the engine. Its a complete loss along with the radiator. The quote is $13,000 for the job!!!! Great news only 3 weeks before I deploy to Iraq for 7 months!
  18. Driving a 1999 996 C2. The air conditioner stopped working not to long ago, and its getting hot. I am not anxious to put the car in the shop, so I am hoping to just recharge it. Does anyone know if you can recharge the system using the store bought recharge kits? If so, where is the compressor and the place that you actually plug the recharge kit in?
  19. This question concerns a 1999 996 C2 Coupe 6 speed. A buddy of mine who is driving my car while I am out of town, said that after pulling to a stop he noticed white smoke coming from the engine. The way that he described it it sounded as if it was coming from around the air cleaner, or from the air cleaner itself, nothing from the exhaust pipes. He let it cool down and then took it home to park it in the shade. He said there was no drop in power, but that the engine doesn't sound "happy" anymore. I think he is saying that it is knocking. I am wondering if this sounds like a problem with the water cooling system, or possibly a lack of oil pressure, causing the engine to overheat. Because I wasn't there to read the gauges I don't know what the engine temp was at the time, or what the oil pressure gauge is saying. I told him to park it and not drive it anymore, as is always suggested, repairs only get more expensive the longer you drive it. I am going to take it on a trailer directly to a Certified Shop, when I get home. Any thoughts on what the problem could be, or suggestions on what to do? :(
  20. One option is to take a penknife around the edge of the buttons to take off the flakes. Basically, you are taking off the plastic outer layer around the knob. By doing this it makes the problem less noticeable. Works quite well actually. I am not sure about the redesigned softer buttons.
