vza
Everything posted by vza
  1. Hi All, I'm going to retrofit my 99 boxster dash with one with a glovebox(going from grey to black as well) Is 996 552 109 02 the correct dash for my 99 Boxster. Thanks Vince
  2. Ok well always try simple first. This problem began only after the hardtop install. I unlatched the rear HT latches and the clamshell popped up a bit. I then just lowered till the light went off and buttoned it back up. Apparently it wasn't fully retracted. Oops....thanks for the help JFP. V
  3. Ok.. How do I test it or is it understood its failed?
  4. Not really understanding. The red clip is used to fool the car in thinking the top is up so motion sensor is activated when top is down. You don't install under the hardtop latch..do you? Where is the limit switch?
  5. Yes, I simulated load with a jack under the wheel carrier ...i went up and stopped when the car began to lift off the stand then backed off on the jack a bit to lower the car. I believe the lower control arm was sort of parallel to the ground. The creak went away for a while then it rained and started coming back. It creaks when I turn the wheel...sounds like its from right shock tower. Thought its the shock mount and was gona back it off a 1/4 turn. V
  6. You put that in place when installing the hardtop??
  7. Hi All, 99 Boxster,, I put my hardtop on(1st time) and everything works but the dash Convertible warning light stays lit. I removed the switch and found a bad solder joint so I re-soldered all the joints(8 joints). Same result, all the functions work ie. window drop, I hear the motor run if I press the top down button. Everything was fine with the soft top. Is it just a latch adjustment for the hardtop? I did not plug in the rear defog plug but I don't think that makes a diff. Thanks V
  8. I found that ....it's not listed somehow. Goes under #17
  9. 99 Boxster Hi All, On my Hardtop there are foam gaskets that turned gummy over the years, and I want to replace them. They are seated under the 2 latches that turn and lock the top into place. Can't find a part # for them. They go under part# 986 563 403 02. Any info would be appreciated. Thanks V
  10. Hi all, Ugh....I was putting gas in my 99 boxster from a 3 Gall can. I used a plastic turkey baster to extend the funnel I was using. Apparently the baster was not gas proof and began to break down and a piece broke and I believe fell into the tank. It was a piece of plastic the size of a pea. I assume it will dissolve and nothing will happen. The tank is half full. Any suggestions. Thanks v
  11. 99 Boxster. Well I decided to paint my Guards Red hardtop to match my Ocean Blue Boxster. Wanted to do something other than Ocean Blue. I saw some pix of some other Boxsters that had their hardtops painted with a black matte finish. Looked pretty cool....almost like the soft top was up. I can paint it flat black or ocean blue and clear it with a matte clear. Not too sure what way to go. Black Matte or matching Ocean Blue w/ matte finish. What do you all think?? V
  12. Hi All, Replaced front shocks,strut mounts,strut bearings,wheel bearings, control arms(wishbone). Now...I'm getting a creaking sound when I turn the wheel. I finished on Saturday and drove the car all weekend and just noticed it this morning.(Mon) Any thoughts? V 99 Boxster Base
  13. Got 1 side completely done. Just a few things. Torquing the rearward bolt for the control arm was guesstimated ...I couldn't get in there w/ a torque wrench even with a crows foot. Dont have that torque extension tool you attach to a wrench. I got it on real tight comparable to wheel lug tightness(calls for 118 Ft Lbs) Next is the axle bolt....340 Ft Lbs ....really? Gona stand on a breaker bar at 19 inches ( I weight 208) What say all? V
  14. Got 1 side completely done. Just a few things. Torquing the rearward bolt for the control arm was guesstimated ...I couldn't get in there w/ a torque wrench even with a crows foot. Dont have that torque extension tool you attach to a wrench. I got it on real tight comparable to wheel lug tightness(calls for 118 Ft Lbs) Next is the axle bolt....340 Ft Lbs ....really? Gona stand on a breaker bar at 19 inches ( I weight 208) What say all? V
  15. Replacing struts,strut mounts,strut bushings, bumpers, bearings, wishbone, and tie rod ends. I assume the suspension has to be under load when torqueing wishbone and components that are attached to it. V
  16. Hi All, I am replacing my front bearings, tie rod ends and wishbone on my 99 Boxster. Considering that I have everything removed I decided to replace the shocks. Anything else I should consider while in there...springs/shock mounts etc..... Ok well now im seeing all dosent have to be removed(balljoints) so maybe I'll hold off on the shocks...any thoughts? Thanks v
  17. OK...I trashed both Tie rod end boot and wishbone boot as well so I'm going to just replace them. Seemed the ball joints were very easy to move around so I think they were shot anyway(someone agree with me!!!) Is it necessary to replace the hub bolt? Should I consider replacing anything else while I'm in there? Thanks V
  18. Ok....The forked part of the tool should go under the rubber boot of the ball joint as to not rip the rubber....correct? Probably should not use a fork(pickle fork I think they call 'em) Thanks V
  19. Hi All, Going to replace my front wheel bearings 99 Boxster Base. I planned on removing the wheel carrier and bringing off to a machine shop to get the old ones pressed out and new ones pressed in...only 40.00 a side. Is there a chance I will trash the balljoints during removal? Should I replace the control arms while I'm in there? Any tips or suggestions? Thanks V
  20. If I remember correctly there are also switches located in the door latch. I had the same issue. You might want to check that as well. V
  21. Hi All, Purchased 7mm and 15mm spacers for my Boxster. Is this going to have any negative performance at the track? Thanks V
  22. Just a follow up. Re-installed my serviced injectors (I think they were off by 2%) not sure what the tech jargon means and R/R my FPR. So far drove about 700 miles with no CEL. Hopefully cured!! V
