RFM
Everything posted by RFM
  1. DSG is manual transmission based, Tiptronic is automatic transmission based.
  2. Have you jacked up the car by the engine crankcase ? If yes look for leaking motor mounts.
  3. Can you explain where precisely the antifreeze on the floor is situated, left rear behind the wheel, rear - middle, etc.
  4. You are right 1schoir this is the procedure for European cars.
  5. The frequent on - off cycle of the compressor in combination with the gas noise confirm my opinion, too less gas. The system contains enough gas to stay active, for example a full system contains 0,850 Kg ( 850 Gr. ) if there is a leak somewhere and there is still 0,600 Kg. in the system, than you got this symptom, once the capacity drops to 0,450 Kg. the compressor cut off.
  6. If you can hear the passing of the gas, it means that the system contains a to small quantity of gas.
  7. If the car is set with the max. negative camber you have to go to the max. toe-in to compensate for the rear and front axle as well, all in the tolerance values of course. I think that you have got the max. negative camber in combination with the max. toe-out what declare the tyre inside wear. It is necessary to top up the fuel tank for a alignment, a difference in weight of approx. 50 Kg. on the front axle gives you a totally wrong result.
  8. Adding a piece of foam behind the back center is not possible, they have a plastic back side which is fit just in the seat back. Perhaps between the leather/textile trim and the plastic back side? Take the top of the center and pull upwards while pulling in the direction of the steering wheel, the fixation hooks are fragile, they are breakable as glass.
  9. Are you sure that the seats are exactly the same, electric adjustable - electric adjustable with memory and/without lumbar or standard with electric adjustable back ?
  10. 5,5mm wrench, torx have not mm indication.
  11. The door lock cylinder mechanical extension is not engaged in the door lock. You forgot to test the door lock manually after reinstalling the lock with the new bow den cable. I hope that you can still open the door with the remote in one or other way. If not call your dealer. Success.
  12. That is the new one Tool Pants, you can see the smaller diameter on the insert #5 at the end of the tool, to keep the plastic ring in possition and to lead/guide the seal in a correct way to the crankshaft.
  13. This rule obtains for all Porsches, the pivot possition point of the parabola/lens is the culprit.
  14. Do you have a RHD or a LHD car? The blower is located under the trim passenger side ( right side for LHD cars ) under/behind the glove box extremely right. The trim and blower removal is easy.
  15. Do a search, the door trim removal should by discussed in the past.
  16. The lower adjuster is only raise and lower, the upper adjuster is left and right but at the same time up and down. For example, the head light is too much to the right - turn the upper adjuster till the headlight is in the perfect left/right possition, but the light is too high now - adjust with the lower adjuster the head light downwards till the perfect up/down possition. Repeat if necessary.
  17. The code is on the sticker, inside of the front hood or in the service manual.
  18. Only the front springs have the same characteristics. 987 S front without PASM 27N/mm stabiliser bar: 24,0 x 3,8mm rear without PASM 33N/mm stabiliser bar: 19,6 x 2,6mm 987 C S front without PASM 27N/mm stabiliser bar: 24,5 x 3,8mm rear without PASM 40N/mm stabiliser bar: 19,0 x 2,7mm Hope it help.
  19. When you put the air condition on ECON, you shut off the air con. compressor. It means that the air con. is off but all other functions stays working, trey with refilling the system in a workshop and do a search for a leak. If the buzzing is still there it could be a compressor issue. The compressor is not the hot water pump that Dennis talked about.
  20. If you got a pic. of the inside black tool, complete with the bolts, i will tell you. It is too difficult to explain in English for me. The black tool have a smaller diameter at the lower end for approx. 5mm than the upper end to keep the green plastic ring in place.
  21. A good chance that the connector between the outside handle and the door lock is coming loose, if not you have to change the lock. Remove the door trim and give a look.
  22. Blower motor replacement time: 1 ( one ) hour !!! Most difficult point: find a 5,5mm key. Regards.
  23. A full tank is required for the alignment.
  24. por911, it is the last version of the tool you have.
  25. An alignment is recommended after suspension work, you can go directly after the shock installation. Don't forget filling up the fuel tank.
