RFM
Everything posted by RFM
  1. You cant open the booster, all you can do is remove the booster pour out and let him dry. This gives you no guaranty for the future replace is the best option. Brakes are a safety item, two hands are not enough, if you got no experience with brake systems go to a workshop.
  2. They can block the oil gallery's and oil drain pumps, remove the covers and clean everything.
  3. The brake booster is located under the black plastic cover, the master brake cylinder is bolted on it. The lift sensor is faulty and is the reason for the two bleeps. ( TWO bleeps = ALARM system fault --- ONE bleep = something not closed ) You mean one of the four plugs on the bottom of the door, in this case no problem.
  4. At the same time, check the hydraulic oil level!!
  5. This is the instruction for the right cylinder bank, the left side is the same without the attach. Change the coils if they are cracked. Success.
  6. There was an action in Europe for the stepper motor !
  7. The car start with the service key, he contains a transponder. The remote is not reprogrammable on a 04, you need a new blade and a new remote. I hope this helps.
  8. No worry this make no leak into the car, but the alarm siren ( and if the car is equipped with a lift sensor - white box ) is/are faulty. There is a good chance that the brake booster contains water, this give you in the future problems with the brakes ( stick ). Pour out the booster A.S.A.P.
  9. Turbo and S brakes have the same dimensions. V6 haves smaller brakes, the rotors are approx. 1 cm. less in diameter.
  10. There is a release cable in the left rear wheel well, unscrew the wheel liner on his back end and you find the cable.
  11. The turbo calipers and rotors are not the same as the V6, they are bigger.
  12. I agree with you, it is only an idea, install the D.V.D. reader in the armrest in the middle of the rear seats, it's easy to install, complete invisible and user friendly.
  13. Hi I'm not sure for USA but there is no certificate of approvement for 19'' in EUR. 986-16'' and 17'' > face lift. < face lift 16''-17'' and 18''.
  14. To open it, unscrew the TORX-screw and pull the connector out the A-pillar. At the same time give a look on the back side of the connector where the wiring gets, in and pull gently for loose or broken connections cause corrosion.
  15. Check the light switch.
  16. After removing the two allen bolts, you have to pull with both hands the tail light out from the front to the rear. There is a plastic clip situated on the rear and approx. in the middle of the light and sticks as hell. You can with a wooden wedge push the light out after protecting the paint with tape, it is a painful moment but after you heard a loud CLAC the light comes out without any damage. Success.
  17. There is a micro switch in the left B pillar ( seat belt area ) you have to dismount the interior trim, the switch is well hide.
  18. There are no longer workshop manuals available over here since the PIWIS tester is programmed as manual for 987-997, perhaps Lauren or someone else can help you with a wiring diagram. Regards.
  19. If it happens only under braking there is 99% chance that the control arms ( the longerons with the uni ball fixation ) are used. Thy are very difficult to check for play.
  20. Hi The correct size is 76 mm and 14 flutes.
  21. Hi The problem areas for that are: MAF sensor - brake light switch - wiring on the front shock absorber left and / or right in the area of the fixation grommet, you have to cut the wire and grommet open, broken wiring by up and down movements of the shock absorber. I hope its helps.
  22. Yellow connectors are always security system connectors ( airbag etc. ) be careful with that. Is it possible that the tilt function inside the seat is faulty ? Take note that the car is programmed for MEMORY SEATS, you have to change that whit a PIWIS tester.
  23. Check for play on rods from sway bar to shockabsorber,silentblocs sway bar to chassis and control arms first.It is not easy without elevator.
