ltcjmramos
Everything posted by ltcjmramos
  1. Looks like this forum is rather moribund. Anyone there? In October last year, I came out of 10 year ownership of a 997GTS into a 991.1TTS. Have put almost 7k miles on it since. Love it! What's not to love?! It came with the DSC, which would have been my first add. I did install Mr12volt Android Auto and the Shark Werks muffler delete pipe. Am about to swap the Sport Design steering wheel for a 991.2 Multifunction wheel. I think that'll be it. I have no desire to tune it.
  2. Plastic or leather
  3. I am effecting a swap of my 991.1 Sport Design steering wheel for a 991.2 Multifunction wheel, both PDK with Sport Chrono. I am installing steering wheel 9P1 419 091 MJ A34. I need the p/n for the airbag to this wheel.
  4. Doing the 80K mile service and have run into a problem. The oil is changed, all filters refreshed, motor mounts replaced, brake fluid flushed, but plugs need to be replaced. Never pulled mufflers with PSE, and am at a loss on how to remove the stainless braided vacuum hoses that are crimped onto the valves. The heat shield (driver's side) is off, but without removing the muffler can only get to two of the three plugs. Hoping for help and thanks in advance. FWIW ... 2012 GTS. The subject of another post on center locks.
  5. Last set of tires bought and mounted at an indie shop, $72 for TPMS. Find another shop.
  6. My related is not putting the key in ALL the way. Key turns, no action. Seat it properly, no problem.
  7. Maybe way too late for comments, but... In shopping for mine last year, I did find a very few with LSD only, but most were without, or with Sport Suspension. A good option if you intend to track the car, otherwise, not needed, IMO. AWD needed if you're in the snowbelt, and intend to drive it through the winter. I was just out on a 1500 mi drive with some friends, one of whom drives a 997TT. After driving mine, he said he missed the dynamics of RWD. Liked the handling of the GTS much better. Finally, if you're considering PDK, Sport Chrono is a must.
  8. Hi Working with Adrian Streathers (noted author of books automobile, mostly Porsche) to provide him pics of the undercarriage of my '12 GTS. I need to get the car up, and underpanels off. Anyone have a 4-post lift I could use for a few hours? Thanks
  9. Hi Am about to put my 996GT3 up for sale, and am considering the 2011-2012 997GTS as its replacement. I am getting different information from dealers on the Sports Suspension (SS) and LSD options, and hoping someone here has good information. First, I was told the SS "option" is standard on the GTS. I think that's settled now, and is identified as a $950 option. But what is unclear is whether the LSD is included in the SS, or is a separate option. Whichever, can anyone give me a description of what the SS option consists? It continues to amaze me how uneducated some dealer sales folks are. (BTW, my other consideration is the 2007-2009 Turbo.) Thanks
  10. Hi May have to change my driving "style" and/or car shortly ,and am looking for advice on how to accommodate this. I have had limited movement in my right ankle for many years. I have been wearing a flexible brace since I had it partially fused in '08. I retained flexibility in it to press the gas pedal, so little impact to driving. However, as the ankle has deteriorated (as expected), I must now wear a stiffer brace that does impede my ability to press the gas pedal. If/when I have the ankle completely fused, I will lose that completely. The two things I am considering now are hand control for the accelerator, and/or getting a PDK-equipped car and left-foot drive. Anyone with experience in these? Source for converting to a hand control?
  11. Found what I need. Inspecting the nuts initially, I did not note that they had flat surfaces, looked round to me. Closer inspection shows that an 8 mm socket fits to loosen them.
  12. Long-time member over on the GT3 forum. Been driving a 996GT3 since Jan '05, and a 993TT just prior to that. As I approach 70, thinking of getting into a gentler/kinder car, and am considering a 997S with PDK. My question is are there any other issues with these early-on PDK's? I know I'm in for a BIG change from the rough and ready GT3, but am ready for that gentler/kinder car (I hope).
  13. I should have asked the right question, how does one remove the nuts on the installed crest?
  14. ltcjmramos
    Hood Crest
    How does one remove the hood crest? I have a silver one on there now, which I'll sell once removed, and want to put on the yellow one.
  15. Can't tell you if that particular part will fit or not, but when I needed to replace my front bumper, I did so with the RS bumper, which, at that time, was much cheaper than the stock piece. And it has air vents! :)
  16. ltcjmramos
    Lsd
    Suggest you go over to the GT3 forum on Rennlist where there have been several discussions on this, e.g., http://forums.rennlist.com/rennforums/996-gt2-gt3-forum/82454-qs-about-gt3-limited-slip-differential.html. If you search "testing lsd" and/or "lsd testing," you'll find several more.
  17. Not sure what function it has other than reporting the outside temp to the display. On my LHD '04, the sensor is mounted in a holder on the right hand side in the lower/larger air duct.
  18. Welcome, you're sure to enjoy the car! Your Porsche education is just beginning if this is your first one. I went from a near 400 hp '93 RX-7 (12 years) to a '99 C2 (3 months, not enough car coming out of the RX-7) to a '96 993TT (1 year) to the GT3. Tracked the RX-7 and the 993TT, and wondered why people said driving a Porsche was a learning experience. My addled brain didn't understand the 993TT AWD implications. When I first took the GT3 onto the track, I was quickly humbled. Can you say "lift throttle oversteer!" I had a blast learning how to drive all over again. For what parts are you looking?
  19. Very good and valid points. Flashing my ECU was to develop better low-end and street driveability since I am no longer tracking my car, not to achieve more hp. I should go back and compare hp/tq curves at that low-end to see what the actual gains were, but there is no question in my mind (butt) that it's smoother to drive on the street.
  20. That's it. How'd you find it?
  21. I have Cargraphic mufflers, otherwise stock exhaust system, FVD Brombacher ECU flash. Much better overall street driveability (more low-end). On the dyno, picked up 16 rwhp, est 19 at the flywheel. I've spoken to others who say they only picked up 6-8 rwhp with headers and other exhaust mods. I would think they'd do better than that, but have no experience there. Many others offer quality ECU flashes to match your other mods.
  22. Don't know if anyone would be interested in this, but I have some old bottled beer that I am about to toss down the drain. Some of it is 4 years old, some 2 years. I'm a non-drinker, and these are leftovers from some gatherings I've had. All of it has been in a cabinet in the garage. I take out a bottle now and again, and my son-in-law and brother-in-law seem to enjoy it. At least, neither has spit it out. If you'd like it for this gathering, I'll be at the PCA-GGR DentPro Day in Campbell tomorrow, and can bring it there for pick up. Let me know, please.
  23. Look here http://gallery.rennlist.com/gallery/album122 for some info. Rockitman references a page on the B&M site that is no longer there. I also have a page, but it's down, too. I even went to the Vivid Racing page, which references a page, which is gone. Thought I found it here: http://www.nyxracing.com/bm-precision-shor...-99-p-7495.html but the link goes to a dead end. If you can't find anything, let me know as I have a hard copy, and can scan it for you.
