Click here to Donate
leeshdw
Everything posted by leeshdw
  1. Loren, Do you have the wiring diagram for the light switch? Color of wire to pin#? Thanks.
  2. Just went to napa auto parts to pick up the ignition switch to give it a try. Replaced it and it and it's the same. Light switch next?
  3. Thanks Loren. Never thought to look at the ignition switch.
  4. I've been havin intermittent issues with my instructment cluser and interior lights (a/c climent, interior buttons). I tried wiggling the light switch but does not help. When driving, in about 30mins to 1 hour or so, it turns on and stays on for inconsisant amount of time. Is it the light switch or is there a relay that i need to check? Thanks
  5. Loren, Can you PM me the troubleshooting steps. I am getting the ABS PSM fault code 4460 from Durametric Thanks.
  6. Loren, I too have installed a fixed wing. I have '02 996TT. I get the spoiler warning light if i go over 74 MPH. Will jumping pin2 and pin5 disable the warning? I've tried the procedure in the earlier post by removing the spoiler drive power wire and moving pin 4 to 2 and 2 to 4. It didn't work. Thanks.
  7. I will be changing my clutch next sunday. Are there any special tools needed to get the job done? Any gotchas that i have to look for? This is for '02 996 TT. Thanks!
  8. Does the engine bracket work on a 996tt? i am going to attempt to do the clutch myself.
  9. I am in need of rear tires. I want to get some Toyo T1R. They do not make the OEM size. The size closes is 295/35/18. Can I run that in the rear? If I can, do i need to match up the front to 225/45/18. Or can I run 225/40/18 until i need new tires on the front then get 225/45/18?
  10. Didn't have time to bring to the dealer yet. I noticed I can't turn on cruise control. I accidently hit the cruise control on/off switch and noticed the light didn't turn on. Is there a similar switch for the cruise control?
  11. No electrical/wiring done on the car. Guess it is time to bring it into the dealers.
  12. Loren, That is the switch i changed out. I noticed another thing this morning. With my parking lights off. When I press my brake pedal, I see the passenger side marker and the light in the headlight light up. I only noticed the passenger side and not the driver side. What else could be wrong? Thanks.
  13. that is the correct switch i got. Part number is correct. what is the Brake pedal position sensor in one of the fault code?
  14. I will verify the part number. The one i changed is right at the brake pedal.
  15. I changed it with this one. http://e-partssales.com/Merchant2/merchant...=986BRAKESWITCH
  16. I am getting the ABS/PSM warning lights. It goes on as soon as I turn on the parking lights. One thing I noticed. All 3 brake works normal when the parking lights are off. As soon as i turn on the parking lights the ABS/PSM warning lights come on. The 3 brake lights comes on without pressing the brake pedal. I checked with my Durametric software and got the following faulty code. 4340 stop light switch P0571 Porsche fault code 364-Brake pedal position sensor I already changed my stop light switch. But still getting the fault code. Does anyone know where the brake pedal position sensor is and how hard is it to change out?
  17. Price is one of the concern and I don't think I will be upgrading to bigger turbos. So I don't need a higher priced ECU flash. I sorta pretty much made up my mind on the UPsolute.
  18. Thanks for the recommendation. I am sure that I will not do anymore mods (power wise) on the car. The other half won't approve of it. So I think the UPsolute path is right for me.
  19. I'll give him a ring tomorrow. Thanks.
  20. I am planning on doing the Upsolute flash. Does anyone know a local shop in the Bay Area or Sacto area that could do the Upsolute flash? I am not planning on doing any more mods on the car. I currently have new DVs, "F" hose and BMC filter installed. Thanks
  21. If I purchase the Durametric Diagnostic Tool. Can I use it to program how the doors lock/unlock. Currently, the doors does not automatically lock when the ignition is switched to "on" position. I recently added a new key. I only received a valet key when I purchased the car. Dealer charged over $100 to program the key. :cursing: Thanks
  22. Hi, I purchased a GT3 Shifter #997.424.010.00 to be installed in a '02 996TT. I removed everything and found out that one of the cable does not have a end attachment. Does that mean I have to replace the cable or is there an option to purchase that end attachment. Here are some pictures taken. Stock Shifter 997 GT3 Shifter Back of Stock Shifter Back of 997 GT3 Notice the stock shifter have a "E" or "C" clip on the shifter and the GT3 does not.
  23. Thanks Loren, Do you know the actual part number for my year?
  24. Can I get a the part number for '02 996TT A/C Heater Control unit. My temperature digits are not displaying some lcd. Will this fit? A/C controller Thanks
