demarconstruction
Everything posted by demarconstruction
  1. Hi My 2004 cayenne turbo that was tuned Is coming up with a code when we use our scan tool, saying overboost on turbo,supercharger (code P234)was wondering if the low budget tuner that did the work did it right as sometimes It gets a good amount of boost and sometimes it seems flat. spark plugs and coils were just changed and no lights are on Anyone know If disc0nnecting the battery would help by resetting the computer ? Thanks
  2. HELLO CAN ANYONE TELL ME THE GAP SPECS FOR A Denso Iridium Spark Plug FOR A PORSCHE CAYENNE TURBO 2004. tHANKS DEAN
  3. you would nt know the size of the caliper...??
  4. hello all Im looking for some info need help finding rear brake pads for my 04 porsche cayenne turbo with 20" wheels the calipers are red for front and back i believe the fronts are 350mm and the rear look smaller the vin # is WP1AC29P84LA94008 thank you Dean
  5. thanks Loren not sure either but it doesnt look like it there is just 1 small retangle plug
  6. Hi all I recently purchased a 04 cayenne turbo with 54k on it I am very happy with It but it didnt come with the original Cd changer which I just bought online I installed It (there was 1 wire coming from the vehicle and the unit has 2 connections unit is getting power but whe i push the cdc button it says no cd changer Is ther something i need to do or did i miss installing another wire. Thanks for the help Dean
  7. Hi does anyone know what the model # is for cd changer and where i can buy one used or new thanks
  8. hello everyone im in need of the plastic peices that are behind the door handles (intereior side) they are a bit scuffed up and would like to replace all 4 thanks
  9. Hi after replacing the left oil reservior holding case for the turbo ive noticed the CEL with 2 codes p0491 p0492 my scan tool shows it as secondary air injection system could it have been from when we made the repairs?? any suggestions thanks
  10. I realize that is there anything else i should look at?? also is it very difficult to replace the case ? thanks Dean <note I'm not familiar with Turbo's -- but on non-turbo 996s....> If it is the case -- and Loren means the engine casing -- than your only realistic choice is to probably have it welded. The oil "pan"/case is part of the entire engine block/casing. If it is the cover and just the cover -- you might get away with either welding it or replacing it. I would see if you can locate the leak by putting the car on ramps and pulling the cover (ground effects cover, not oil pan cover) below the oil pan/case and trying to see if you can locate the source of the leak or any obvious physical damage. Before turning the engine over (even if it is to drive up some ramps) -- make sure you have sufficient oil. m Thanks I found the leak i cracked the left side of the turbos oil collection housing a 95.00 part . :) .... youve been alot worse for a stupid stunt!! thanks again Dean
  11. I realize that is there anything else i should look at?? also is it very difficult to replace the case ? thanks Dean
  12. I realize that is there anything else i should look at?? also is it very difficult to replace the case ? thanks Dean
  13. Hi all I recently was out driving and backed up over a curb and now notice a oil leak behind the drivers rear tire not sure what it could be coming from any suggestions ill jack up the car tomorrow if anyone can help out with what i should be looking for thanks Dean
  14. i have a 996tt and was looking for opinions on replacing my spark plugs with ahigh performance one since my car is tuned 490hp stage 1 ecu any suggestions thanks
  15. I installed a new maf sensor and disconnected the battery for 10 min it seemed to work fine for awhile until soon after when id go and start my 996TT that the minute I put it into drive the ABS PCM lights would go on - I finally reinstalled the tuned software I purchased from fvd.Us and it cleared it out for good -- my only question is now it seems to lack the initial power and seems a little hesitant im wondering if I need to do anything else to the new maf sensor or if after driving the Car with the ABS and PCM? lights I fouled the spark plugs???? thanks for any help
  16. well im a t a loss! i have a 02 996 tt with pcm (have that code ) but when i put it in it wont accept it so im figuring on it also needs the navigation code but thats not illuminated are there certain buttons i have to push together to get me over to the navigation screen??thanks
  17. hi all i need to get a navigation code have the pcm code but i believe i need the nav code only not sure how to access it since it doesnt illuminate on the screen it asks for the pcm code which i put in but rejects it and after a few tries it make sme wait a hour!! thanks
  18. my maf sensor seems to have gone after use of a k and n air filter upon examination it looks like new even cleaned it but still the same fault codes p0102 and abs ect ordered new sensor my question is once i install new sensor do i need to reset anything on car like disconnecting battery clear fault codes?? thanks
  19. anyone know how to get the serial # from from 02 996tt ?? steroe -there is no tp button... thanks dean What is the model number on the front of the radio? HI THERE IS NO MODEL# MAYBE BECAUSE I HAVE A FACTORY NAVIGATION SYSTEM EQUIPPED??
  20. anyone know how to get the serial # from from 02 996tt ?? steroe -there is no tp button... thanks dean
  21. i too lost my code for a 2002 996tt cdc-3 #11091324
