Ok, I was making this list up anyway, so here's a complete rundown of all known maintenance.
The car currently has 94K miles and the driver's side window is starting to squeal, the ds seat warmer has quit, the load/eject mechanism of the CDR-220 has quit, and I've got an intermittent brake wear light. I'm going to have to do a coolant flush and replace some hoses soon, and a brake pad replacement isn't too far behind that.
All known maintenance for 1999 Porsche 996 Carrera Cabriolet
12-29-03
Mileage: 53,861
Symptoms: 45k service, Shorting coils due to tube seal leaks, bottom out left hose bad
Repaired by: Sports Car Repair
Service Performed:
Oil change
Replaced pollen filter
Replaced spark plug tubes
Replaced large O-rings
Replaced small O-rings
Replaced air filter
Replaced spark plugs
Replaced left rear bottom out radiator hose
Notes that slow leak in RR tire, clutch worn out
Total: $640.32
09-08-04
Mileage: 59,538
Symptoms: CEL 1125, 1123
Repaired by: P.S. Foreign Car Care
Service Performed:
Replaced Mass Air Sensor
Replaced coolant temp sensor
Total: $647.80
01-04-05
Mileage: Uknown
Symptoms: Oil seepage, alignment
Service Performed:
Replaced head cover
Replaced front cover seal
Replaced rear plug
Replaced upper tube seal
Replaced lower tube seal
Replaced exhaust bolt
Replaced Manifold gasket
Replaced rear main seal
Four wheel alignment
Total: $938.59
10-06-05
Mileage: 65,317
Symptoms: Ignition switch sticks, oil leak, door pocket lid broken
Repaired by: Momentum Porsche, Houston
Service Performed:
Premium Oil Change
Replace complete ign lock assembly
Brake system flush
Replaced cigarette lighter complete assembly
No oil leak found
Door pocket lid repair declined
Total: $1156.07
07-01-06
Mileage: 76,817
Symptoms: CEL, codes P1124, P1126
Repaired by: The Bug Clinic
Service Performed:
Replaced serpentine belt
Replaced air filter
Replaced fuel filter
Total: $554.47
07-21-06
Mileage: 77,809
Service Performed:
Fuel Injection cleaning
Total: $105.97
09-20-07
Mileage: 82,000
Symptoms: Airbag light, CEL, slipping clutch
Service Performed:
Replaced seatbelt sensor
Replaced leaking motor mount
Replaced clutch
Reupholstered rear deck
Fixed driver's side door pocket lid
Replaced Exhaust gas recirculation valves
Total: $1200.00
01-10-08
Mileage: 88,000
Service Performed:
Total: Warranty
02-24-08
Mileage: 89,112
Symptoms: Metal showing through tire tread
Repaired by: Firestone, Champion Forest
Service Performed:
Oil Change
Bridgestone Tires with Uni-T package
Lifetime alignment, wheel balance, tire protection plan
Brake system flush
Total: $1565.78
05-01-08
Mileage: 92,179
Symptoms: Won't hold idle, stalls
Service Performed:
Replaced Mass Airflow Sensor
Replaced Air Filter
Fuel System Cleaning
Total: $849.31
05-31-08
Mileage: 93,500
Symptoms: CEL, high idle
Service Performed:
Premium Oil Change
Replaced cracked Oil Filler Tube
Replaced Oil Pan & Plug
Replaced Battery
Total: $892.34
