drem914
Everything posted by drem914
  1. Bill, I'll have to look for you, too. I work in Foothill Ranch (Bake and Dimension), but live down near Antonio. I have a Seal Grey '01 986 with black top, de-ambered rear lights, tinted windows and the rest of the turn signals and 3rd light are also grey.
  2. Off the top of my hand, I believe the cats and O-2 Sensors are different. Simply swapping in a 3.2 Exhaust I don't believe will work. I "believe" (and I could be wrong) you'd have to also run new wires for new O-2 sensors. In addition, the MAF may need to be re-mapped as well as the ECU. If I'm not mistaken. the 2.7 has 2 O-2 sensors, whereas the 3.2 has 4. The cats for a 2.7 and a 3.2 through MY 03 are the same. part numbers are the same. 4 sensors from year 2000 on. The O2 sensors from 02 to 03 have different part numbers which probably means the length is different. I just swapped a full system (less sensors) from a 2002 3.2 into my 2001 2.7 because my header/cats were rattling. I still have the secondaries that are in good shape if anyone is interested in them. I also live in CA with terrible smog testing, so I didn't want to have any problems from installing after-market headers or cat bypasses.
  3. Ekam, Why is one of the shots in front of Toyota dealership? Does anyone know if the carrera lights 18x8, 18x10's from an '05 997 will fit an '01 986 Boxster?
  4. Already do and found a good use for the right side cup holder. It is a perfect resting spot/slot for my Blackjack II Smartphone. Keeps it in site for GPS and incoming calls and the power cord doesn't have to go to far to the cigarette lighter
  5. UPDATE: Today I lit a spark under my *** and went to troubleshooting. I pulled the dash speakers and swapped them. Right sie still does not work so the speaker is now known to b good. The only two things left are wiring and the amp. Can anyone tell me what pins to check at the amp connection to test for continuity so I can rule th wires out? As Loren likes to say: "Have you used the search function on this site? it has been covered many times before." http://www.renntech.org/forums/index.php?s...st&p=144770 Respectfully, after searching spark plug changes and reading mulitiple non helpfull posts, I must say the search function leaves much to be desired. However thank you for the reply. That was exactly what I needed. :-) I know i get that too. The longer you are on the board though the more you know which are repetitive questions and how to filter for selections a bit more precisely.
  6. UPDATE: Today I lit a spark under my *** and went to troubleshooting. I pulled the dash speakers and swapped them. Right sie still does not work so the speaker is now known to b good. The only two things left are wiring and the amp. Can anyone tell me what pins to check at the amp connection to test for continuity so I can rule th wires out? As Loren likes to say: "Have you used the search function on this site? it has been covered many times before." http://www.renntech.org/forums/index.php?s...st&p=144770
  7. Do a search for OBC hack. You will have to make up a wiring harness that plugs the stalk/switch to the the white plug behind the instrument cluster and ground the switch. like this obc hack or this obc wiring.
  8. As a new owner to a 2001 Boxster, I have a question? Are there speakers in the door? I see the grills....but I don't get any sound from that area If you have the door grilles then you should have the speakers behind them. They are for the low frequency only as the dash speakers are the Mids and Highs. Do you have the rear speaker package behind the head rest in the storage compartment? if so your fad may be mis-adjusted. check your settings. Put your hand on the grill area and see if you feel anything as you turn up the volume. Remember the Becker radio stores different settings for radio, CD and aux.
  9. Use a product call Ragg-Topp from Hartz. You can order it from performance products or suncoast. it comes in a 2 piece package with cleaner and sealer, or you can order the sealer only.
  10. Check for a Cracked a/c pulley wheel or bad pulley bearing. Had the same thing. Went away when A/C was off and came back when the A/C was on.
  11. Thank you for the explanation. This weekend I'll pop off the cluster and check the wiring.
  12. Sorry, but not sure what you mean by the "pins go to ground" when the stalk is pushed. Can you elaborate? Can I check this with a simple volt meter?
  13. Next time at the shop I will have that done since I don't have access to a tester.
  14. Thanks. Just picked up the extra wires at the local VW dealer to complete the connection from pin 6 on the stalk plug to pin 25 on the dash plug. Now that I have taken it apart before should be a snap to do this weekend. (update 06/01:) Now having installed the last wire from position #6 on the stalk harness to #25 on the gray connector. no change in function. I still am unable to reset the MPG display or mileage from the stalk. I can reset trip mileage using the odometer reset button, but that is it. any suggestions on resetting the the OBC without having to always disconnect the battery? That will get old real quick.
  15. Anyone know the interior diam on the exhaust headers for a 3.2 S motor vs. the 2.7 base motor? OR if there is any?
  16. I am experiencing the same issue regarding not being able to rest the OBC. I have control up and down as well as forward for the speed set control I just do not get a RESET on my mileage. I have a 2001 MY 986. I have 5 wires from my harness connecting to the 4th stalk. I know for sure that pins 22 & 23 control correctly and which ever pin is controlling forward motion on the stalk I don't know if that is considered front? the issue seems to be with the opposing motion (that would control the reset.) Can anyone clarify the pin arrangement. it seems that everywhere I look I get the same pin wiring diagram. Late cluster (MY01 and newer) Loren are you saying that I need to have 6 cables coming from the stalk harness? I understand lever right, left, front and rear, but what is meant by the description "Lever Inside". I don't have a switch on the end of the stalk and can't push it in.
  17. I am experiencing the same issue regarding not being able to rest the OBC. I have control up and down as well as forward for the speed set control I just do not get a RESET on my mileage. I have a 2001 MY 986. I have 5 wires from my harness connecting to the 4th stalk. I know for sure that pins 22 & 23 control correctly and which ever pin is controlling forward motion on the stalk I don't know if that is considered front? the issue seems to be with the opposing motion (that would control the reset.) Can anyone clarify the pin arrangement. it seems that everywhere I look I get the same pin wiring diagram.
  18. Saw this on the 986Forum and wondered if anyone has tried it yet? 10+hp gain with exhaust mod Not really, but it is supposed to sound like it.
  19. Two very big thumbs up for Jamey Rawlings from me too, I consulted with him a lot when designing my system, he made door baffle boards for me and led me in the right direction in making my own sub box, similar to what he does. The 8" sub in the footwell is the real deal. Do you have a photo of your sub installation?
  20. So is it better to put the fishline in the front section and pull the harness through from back to front, or would it be easier the other way, ie put fish line in from back of car, and pull harness from front to back. With the sill route, the scariest part seems to be under the passenger footwell - allegedly the carpet there is attached with plastic cement glue, and I don't want to irreversibly damage anything... ! Is it possible to route the sill path, WITHOUT having to disconnect the battery? You want to disconnect the battery so you do not activate the the air bags by mistake. I found it easier to pull the wires forward. I've only done this once so I could be wrong (not the first time.) This way any slack is up at the head unit and not down behind the roll bars. Getting the wire along the edge of the carpet along the passenger foot well was the hardest part. Take your time the glue will come loose and will re-stick after you press it back in. You then run the cable under the foam dash cover and you are at the head unit. Run the connector up to the head unit, insert correctly, hook your battery back up and reprogram the radio. Check to make sure your left and right are hooked correctly, test the fade and your are golden. Enjoy.
  21. There is also an alternate route for the cabling going via the centre console which is allegedly much easier than the passenger sill..... see bottom of attached PDF (from another poster). I believe this won't necessitate disconnecting the battery, so no problems with airbag lights, electric window calibration etc..... I am going to attempt this soon and must admit the instructions aren't very clear in describing the steps to get the harness routed from the clip on the roll bar, to under the carpet to the centre console. If anyone has some pictures that would be great! Thanks for the instructions, I will be looking at theis this weekend. While I have the car apart I will check out the "easier softer way" to see if those instructions make sense while I'm sitting in the car. Bill The routing though the sill is not hard at all. One of the best things to do is use a fish line from the other end and just pull it though. To get from the back to the front should not take more than around a half hour in and out including, the removal of panels, plugging in the the connector to the head unit and putting back the panels. I was surprised how quickly it went.
  22. Yes they do, but only if it is obvious. If there are cats in place like the secondaries with proper sensor wires leading from them, there are no CELs going off on the car and the motor is operating within acceptable emission limits you will appear to be compliant.
  23. Well I had and normal oil service yesterday (85,000 mi) and got a confirmation for the sound my exhaust was making. Apparently my front cat converters are going out. They have that rattling and sputtering sound. I don't have any codes coming up yet. I still have time for a solution and am trying to see what is the better way to go. Since the fronts are part of the headers I have a couple of suggestions: 1. Replace the front cats and headers with clean stainless headers and hook them up to new rear cats and the existing. 2. Replace the front cats and headers with new cats and headers, install the rear cat bypass pipes and connect to the existing exhaust. First of all can I do option one without error codes? That will let me know if this is even an option. Any suggestions from the fine people on here if this is even a good idea or am I creating more problems for my self as far as performance issues, mileage or damage to the the exhaust. This is my daily driver and want to keep it as trouble free as possible. If option one is possible any recommendations on suppliers for new headers and the rear cats? Thanks,
  24. I would suggest, if you have an i-pod, Zune or other mp3 player, that you will be much happier installing the adapter cable for it and the mp3 player instead of the cd-changer. To date, I have about half my audio library on a Zune connected to the aux cable for the CDR-220. I just set it on shuffle and have around 2000 songs in almost any rotation i want. It is like having your own radio station. It give you many more options of cds or songs to listen to 6+1 CD vs 200 CDs or more. It is also less expensive ($25 US) than tracking down a previously used CD changer (maybe $200US.) Also, you don't have to go into the front trunk to change discs. The quality of sound is comparable to having a CD playing.
