Prhartley
Everything posted by Prhartley
  1. Based on the codes and that amount of metal, I would suspect the ims bearing has disintegrated.
  2. I would check to make sure that your intake tubes after the mass air flow sensors are properly connected. If they are loose that could cause the engine to stall due to the amount of unmetered air entering the engine. Past that I'd need to know the fault codes.
