ekstroemtj
Everything posted by ekstroemtj
  1. Was it difficult to replace? Mine looks not good on the other end which is going to the intake. Part i have already here but didnt start yet.
  2. Yesterday driving home from my holidays in france. On the way i already feel the car doesnt have that much power. I thought maybe the very high outside temp could be one reason. Max speed which i got 240. thats a joke for a Turbo S. When i had the warning on my display to take fuel i know there are many kilometers i can drive on the last liters. But what happend here i never saw before. The display is showing the remaining km you can drive until your tank is empty. I noticed that this number went down within some minutes from 90 to 40 km very fast. Even i was driving very careful during this short period. Never could be the car used that much petrol in some few minutes. I paniked almost because highway and no station so far. I take next exit and luckily found a gas station. I was thinking what was this. Some problems with the gauge. Some problems with fuel pumps?
  3. You can open. Take away the black plastic caps. Down you will find camshaft adjuster. Have a look: http://www.pelicanparts.com/techarticles/Porsche-Cayenne/40-ENGINE-Valve_Cover_Gasket_Replacement/40-ENGINE-Valve_Cover_Gasket_Replacement.htm
  4. Is your car driving normal? Not at all? How feels your engine?
  5. Rado.... Please take the advice of the guys writing to you serious. This codes which you have and the problems your car is showing you cant solve by yourself. To serious. To difficult.
  6. There is no warnimg for the reservoir. Sometimes only if you have to top of water regular its a sign maybe. Turbo alternators are watercooled. Thats why
  7. Hi There is a lot more which can fail. Isnt neccessary that you get stranded but maybe is causing you headache. Just from my experience and what happend to me in the last 5 years with driving different cayennes. Some things you mention already. There are few more to the list. Not only the big plastic coolent tubes can fail, there are some small ones under the intake manifold which get bad after years. Happend to me. You cant continue to drive. Cardan shaft is failing. Usually you feel it and you hear it when trouble is starting. I would check it. Coolent reservoir. Exploision of the reservoir is a problem which happens to many guys here. Water inside the car from glogged sunroof drain holes. Causing strange electrical problems. I had permanent PSM failures which sending the car to limp mode. Possible to drive but slowly. Check the forum for posts " wet floor" Do some checking with your alternator. I had a failing one close to my home. Thanks god. Isnt neccessary all this things will happen to you but be prepared it can be.
  8. lewis......... about the scanning tool try iCarsoft for Porsche. it helped me a lot with scanning and finding codes. Its not durametric of course but for basic things more than enough
  9. Here is the pic. Part no. 5 on the picture down
  10. I have one which is making me trouble sometimes. The panels get stuck here and there and when driving with open roof a little bit faster i didnt work at all after. I needed to close manual with emergency tool. I need to check the wind deflector now. Its not open proper on my old Turbo. I found a helpful document. I made a screen shot and would like to ask what and where is this part no. 5 on the last picture down. Thank you in advance
  11. I dont know how difficult to do this. I read many times here a lot of guys did it as DIY. Will report
  12. I could not solve the problem. Solution bought a hose. 2 m. Connect it to the reservoir in the sunroof. Routing like the original. Just on the dash board i go down passing the fuse panel to the floor. Carpet still wet. Will see how i can route it under the carpet.
  13. Sorry maybe my mistake. We talk about the bank on drivers side. Bank no. 2. Cylinder no. 5 was the first problem. Now on the same bank cylinder no. 7
  14. Old post but would like to refresh. My driver side power window still working but it makes some squeaking noises. Any idea?
  15. Not that i dont trust mechanics but today i checked what they did and surprise surprise. The changed the spark plug gasket and valve cover gasket because i had oil in coil tunnel for cylinder 5. i take away the engine cover and take out all coils. What i found? Oil in coil tunnel number 7. AMATEURS or what should i say. Car is going back to service straight away.
  16. Found answer. O ring must be. Thank you
  17. Stupid question maybe... Do i need a new seal when i am drainibg this oil from this intercooler hose?
  18. You are a very brave and handy person!!! Congrats. The problem would just be how to find the right gasket/ seal
  19. I will try to get access to the MAFs . Thank your for advice how to do. the boost pressure sensor im a cleaning regular. This is always Improving driving and shifting. Looks like i have oil in the air stream. Need further reserch
  20. Thank you for answering. If i try the dipstick or the oil fill cap there is a different idle. The MAF i have to try. Difficult to get them out
