redzero
Everything posted by redzero
  1. I changed the hose today 140$ .. idle is better now . the idle drop is less shaky right now and smother but still there I well hunt for more leaks. I well update you guys and remember to check for -fuel pressure or fuel pump related -vacuum leaks -engine mounts -throttle relearn or to be done in dealer contribute in my thread guys
  2. here is a picture of the with arrows marking the cracked hose and the cracks location
  3. today I noticed multiple cracks in this hose directly above the throttle body part number 94810721702 in the diagram hose number 5 pcv to intake hose I well replace it soon
  4. does it happen also when you turn the AC on or does the idle dip when you turn on the AC then recover very fast test this also while on stand still please check and reply
  5. hi you can check vw touareg forums exactly same suspension its there lower/ upper and drive shaft as well
  6. Thank you Loren I well order fuel gauge and the purge valve and new fuel cap also fuel pumps recently installed and I well check the rubber rings that secures the filter and valve in the tank -what is the size of the thread in the fuel gauge is there any reported throttle valve failure
  7. just pulled these codes P2187 System at Idle Bank 1 P0441 Evaporative Emission System Incorrect Purge Flow P0509 Idle Air Control System RPM some symptoms I noticed with the idle will dip then come back within 1 second to normal when I turn the ac idle will dip then come back within 1 second while coming to a stop
  8. after reading many forms and posts here is the conclusion -fuel pressure or pump related -vacuum leaks -engine mounts -throttle relearn I noticed that when I turn on the ace the rev needle well drop then recover with lots of vibration any idea about the throttle relearn procedure ? all welcome to reply in my topic
  9. im new to this forums so hi all cayenne s 2006 whithin this year new fuel pumps new mafs throttle body clean new radiator new coils and plugs last all cayenne idle drop engine vibrates when coming to stop even in traffic when you drive and stop once you stopped idle rpm drops littke bit some vipration or alot come from engine area then it idle normally again these been posted numerous time but never been resolved or answerd in these form all can relate is engin mounts ?
  10. is it the last updated coil or they well release newer after few months my coils have crack on them so should I upgrade or wait until I get misfire codes also I visited beru website and they have this part number is it the same part 0040 102 012 or the Porsche part is different
  11. hello guys to update the radiator was leaking some of the cores had micro cracks and they will leak only at high tempretures radiator was replaced with regards
  12. hi all to update both maf replaced pumps were fine whats unusual is before pump replacment it was running fine thank you all
  13. but it was running fine before the pump replacment as long as i keep the tank full i will do ther pressure check and i will test the pumps one by one and i will take it to local service to get it scanned for codes and i will report here thank you
  14. Dear all my passenger side pump started to whine so I done the relay test and it turned out to be the driver side pump faulty so I bought the two pumps and replaced them following the diy I also replaced both flanges on top the black one with the filter and the white one with the regulator now my car will randomly stall mostly during warm up or some time in stopping light I opened the tank and rechecked the connection all seem to be fine .also the time I opened it there was a lot of pressure in both pumps as I can see both hose going to the filter are priming any suggestion would appreciated ? with regards
  15. Hi Everyone I am Thinking of returning back to the 18 inch wheels for better ride/comfort/noise /vibration/harshness Or should I stay on the 20 inch ? Please advice me With Regards
  16. where does the hose no 1 goes and where the hose no 17 come from
  17. ok wher does the hose no 1 goes and where the hose no 17 come from all i can see is the two hoses connected to oil housing/cooler ?? but i cant see the others where are they connected two
  18. post pictures where these houses are located and how they beacuse icant see any thing
  19. thank can someone post pictures where these houses are located and how they beacuse icant see any thing
  20. hello all my cayenne s always smells coolant pipes done water pump done no visible leakes i even replaced water pump again smell seem to come from radiator area and ander the front fender i have to putt coolant 1 litter coolant every 4 days car runs smooth and crisp except the coolant top up so any suggestions
