geoff
Everything posted by geoff
  1. Do you have a 2001 model car? My '01 Boxster has the soft touch finish from the factory on most of the interior parts, and if you look at it wrong it scratches, flakes, bubbles and/or peels. Much of my interior was replaced under warranty. Now the car is out of warranty, and parts are scratching, flaking, peeling, etc. again. I have heard the only option is the scrape everything off (a nasty, tedious and time consuming job), then properly prep and refinish the parts affected. If you want a first class product and aren't worried about the cost, Mr Bumperplugs is the guy I would call. My car has a black interior and I heard about the spray version of the goo you dip pliers in to get soft handles. I picked some up (I've seen it at Harbor Freight, Home Depot, and lots of hardware stores), but haven't had the time to try it out yet to see how it matches and holds up. I'm on a business trip to Europe, otherwise I'd tell you the exact name of the product, but I think it's PLASTI DIP® SPRAY - see http://plastidip.com/consumer/products.html
  2. Is the amount of throw the same on both the 996 B&M clone and the 997/986 replacement ? Although Porsche claims approximately 20% shift reduction, I measured 25% on my 2001 5 speed Boxster. At first it felt really short, now it feels just slightly shorter than the original, has the same basic smooth feel as before, and I can use one finger to shift. It definitely feels easier to shift than when I first installed it. I attribute this probably to plastic on plastic wear between the shifter and housing. Before I installed it (i.e., out of car), the shifter would stay in whatever position I placed it (due to friction), whereas the one I took out would always flop off to one side. I wish I could claim originality here, but I found a guy in Alabama on Rennlist that used the 997 shifter on his 996 - see http://forums.rennlist.com/rennforums/show...38&postcount=19 (he emailed me saying it should work on my Boxster) and the side-by-side pictures from http://forums.rennlist.com/rennforums/show...19&postcount=17 made me realize the housings were probably the same. Note that dealers will all tell you the new short shifter won't fit in the older 9x6 cars It's also interesting that Porsche now says to use the new shifter once the old stock is used up. Maybe they figured this out by reading these forums :D
  3. Try this for starters: http://www.brackenrig.net/OBC_Hack.htm I think Tool Pants has a DVD showing how to do the install: http://www.renntech.org/forums/index.php?a...code=_9x6_Werks Given all the frustration I had installing Litronic headlights and the Porsche short shifter using printed instruction, I would probably buy the DVD to watch someone do it first instead of relying on several sets of printed instructions from the internet. You have to make up the wiring harness using the VW wires and BMW connector. It takes less time to do than read about it. I handed my dealer the instructions I printed out, the new stalk for the OBC and the wiring harness I made up and they installed it
  4. When I bought a set a few months ago, Carnewal in Europe was the least expensive, even after getting hit with the Euro to dollar exchange rate and shipping charges. I think I ended up paying around $125 total or so for a set of 4 Porsche colored center caps. See http://www.carnewal-europe.com/cpx_p97002.htm Surprisingly, shipping was much faster than for parts I've ordered from domestic dealers
  5. And the answer is... Before The silver/black crest was pretty stubborn and wouldn't come off with a little jewlers screwdriver, so I heated it up with a blow dryer on high for a couple of minutes, and it came right off During The monochrome and color crests (part number 996-637-443-00) look to be the same shape, but they're not exactly! The new one is less pointy and wider at the bottom of the crest. So I used a jewlers screwdriver to carefully carve out more room for it to fit in the recessed space from the old crest - checking fit frequently After It's not 100% perfect if you examine it under high magnification, but looks just fine from 4" away. I used some high quality black silicon as the adhesive, since it looked like a little button of clear silicon was all that was securing the original one in. I clamped it for a few hours until the silicon started to cure, and wiped away any excess silicon that spilled out before fully cured. (I pulled the key apart - remote electronics and key blade - when working on it, glueing and clamping to mimimize danger of messing anything up).
  6. OK - I couldn't wait for the Ontario tour and bought the colored crest. My black-and-silver one seems stuck on pretty good. Where did you pry up, and did you end up destroying the old one in the process?
  7. Tightening the bolts holding the bleeder valve hasn't helped with the moisture (slime) on thr trunk lid above the coolant cap. Dealer service manager said it is normal, and mine is much drier than most. On another (less technical) Boxster board the other week, I saw a posting by somebody suggesting replacing the two rubber O-rings inside the bleeder valve. Part numbers listed were 999-707-370-40 and 999-707-371-40. Has anyone replaced these and found it solves the moisture problem? The guy who posted thought he disturbed something when he replaced his water pump, and this procedure solved his problem. At less than $2 for the O-rings, I might try it. How tight do I tighten the bolts on top of the bleeder valve (torque setting)? Nothing mentioned about this in the Bentley manual. Anybody know the recommended tightness (other than "just snug enough")?
  8. Very nice! Thanks Jeff. Now I can upgrade my car to look just like an '02 - or at least my key will
  9. Very nice! How does the colored Porsche shield attach - snap in or glue? If you want to come down and do a work on car keys after the Ontario tour, here's a link to the flyer: http://pcala.clubpublish.com/Default.aspx?...ails&eventid=27
  10. As I start doing more things to my car, it really would be nice if there was some documentation on what new parts work on older models. I'm sure with the 997/987, some parts will work on the older models and others won't. Porsche has to be doing something like this so they can claim 80+% of the parts on each new model as being new. A reference would be nice, maybe this could be another forum here, just like the DIY one. :thumbup: Hey Loren, are you listening? I will order the colored crest. PCNA is doing an open house and "VIP" tour of their parts distribution operation in Ontario, CA on April 8. Parts are 20% off. Not as good as Sunset, but no shipping, so works out OK for small/cheap parts like this. Maybe some of you Northern California guys want to do a field trip that weekend! Everyone could see and buy parts in the morning, then do a work on cars session that afternoon in the parking lot. :D
  11. I've got an '01 Boxster (3 button remote on key). I saw a key for an '02, and it has a colored Porsche emblem on the back side. Mine just has a plain (non-colored) silver Porsche emblem. The '02 and later style looks much nicer :D Are replacement key head covers available with the colored emblem, without spending $100+ for the electronics inside? My dealer parts guy said "no". I looked at the PET and the Renntech Retail Price search, and part number 996-637-443-00 is listed for 02 and later models and is described as "emblem colored for key lamp and remote control", list price of $7.50. Will this just stick on and I've done what I want? Nothing could be this easy, could it? Anyone know what 996-637-443-00 really is and how it fits?
  12. This is what my dealer uses, from MOC Products I mixed this with the P21S Windshield Wash Booster (bought locally from Performance Products, only because they were convenient), added lots of water, and it works just fine
  13. I installed the Porsche short shifter 997 424 983 00 in my 986 (which I think has the same exact shift housing as your 996) and it fit/worked just fine. It is not the same as the Porsche rebranded B&M short shifter. I have also seen reference to Porsche part number 000 044 700 26 on the Porsche web site as a short shifter, but don't know what the difference is.
  14. Loren - no worries. This site is so much better than anything else out there :D
  15. I can be a real spaz at times when it comes to mechanical things, particularly in my Boxster where I care how it works and looks. When I installed the Porsche OEM 997 shifter with housing in my 986, I only used the B&M instructions. (Well, I did spend some time with Tool Pants, who gave me a few pointers, only a few which I remembered). The B&M instructions gave me enough details. The biggest problem I had was getting the rear center console out without buggering it up. The trick is to slide the passenger seat forward, then tilt the seat way back. In hindsight, I would have also bought the DVD (look under the Online Docs Menu) for 9x6 Werks DVD (same comment applies to the Litronic installation). If you have a 986 (don't think so, based on your screen name), you might also want to get the Bentley service book.
  16. Thanks Loren, it works now! What happened to step 1 when I upload a new product? The process starts in step 2 of 3!
  17. Unlike the rest of the site, it's not at all obvious how to post a product review. I just installed the Das Schild hood liner on my wife's 997 and thought I'd write about the product. No luck. I think the "Upload Products" link doesn't work (I'm guessing that's how you start a review for a product not already listed) Any guidance / suggestions?
  18. The "Flash" marketing info is at http://cl.exactt.net/?ffcb10-fe5c117170620...-ff081570756402
  19. Try Joanne at ColorPlus I used the black Surflex leather dye on my handbrake after I slightly scuffed it installing the short shifter and the color match is as perfect as I can tell
  20. Is that really an antenna?!
  21. What are the "Porsche approved" washer fluids? My wife's Carrera is out of fluid, so I stopped by Pep Boys to buy some, open the owners manual to see if I need to do anything special, and it actually says to use only Porsche approved washer fluid! This is the most ridiculous thing I've read. Do I also need to use Porsche approved air to fill the tires?
  22. See my first picture in http://www.renntech.org/forums/index.php?showtopic=7371 I think the cable alignment tool part number is 997-424-383-00
  23. When I went looking for Litronics, Brandywine was the cheapest by a few hundred $$. You might want to call them and see what they're charging. I think one of the other Porsche boards had a group buy on Litronics from them last year. I paid about $1100 one year ago. YMMV
  24. My car used to get lots of vibration in the steering wheel starting around 75 MPH. (I have 38+K miles on the car, original front tires, original rears replaced at 27.5K). When I took the car back to America's Tire (same company as Discount Tire) at around 37K miles, they rebalanced my rear tires ($0 because I bought the tires there), and because they are so nice, also rebalanced my front tires for no cost. Driving home on the freeway, absolutely no steering vibration affer that :D You might want to get your wheel balance checked first. I think sometimes the little stick-on weights fall off. And it's a lot less expensive than an alignment
  25. Update: Left the Porsche battery maintainer plugged in overnight, and it started right up this morning. Drove it for a while with several stops, and it seems OK. Not sure if Optima batteries recover faster or not, or if it's just because it's a relatively new battery, but I was very pleasantly surprised. This alone suggests your ignition switch has failed. Do a search on the forum fo 'Ignition Switch' - there are many threads about it. The dealer replaced the ignition switch wih the new style about a year ago. When my alternator failed and sucked my old battery dry, the dash lights did similar, unpredictable funky things. I think the very low battery weirded out the computer, which is why the dash lights were acting strange. The low "clic, click, click, click, ..." noise seems to have been the windows trying to close after opening and closing the door. The noise stopped once the maintainer put enough charge back into the battery. I'm still not sure what the problem is. Maybe I didn't close a door properly. Last time I drove the car (right before Xmas), I exited from the passenger side without opening the driver's door (parked close to the wall and didn't want to get dirty) - first time I did this. About exactly 4 years ago, I had LoJack installed. The battery is supposed to be good for 2 years. Their customer service on the phone this morning was clueless, but 1) they did answer quickly and 2) they really tried to help. I plan to schedule a LoJack service call when I have a little free time. About a month ago, I installed a short shifter, requiring disconnecting and reconnecting window switches, seat heater switches and alarm microswitch for the rear center console. Even though the car was off and the alarm wasn't set, this might also have caused the problem. I have to take the car in soon for the annual service, so will have the dealer check current drain, alternator output, etc. at the same time. In the meantime, I expect the battery maintainer will keep things working. I'll post an update when I know more Thanks for all the suggestions so far...
