Search the Community
Showing results for tags 'oil pressure'.
  • Search By Tags
  • Search By Author
Calendars
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 6 results
  1. Hello. This is my first time posting as this is my first issue with my 2006 Cayenne S and this is also my first Porsche. The vehicle had an aftermarket radio in it when I purchased it and I changed that radio for another one that supported Apple CarPlay. both units are made by pioneer and after looking at the backs of them it appears to be plug and play. I changed everything out and fired it up and everything was great. No issues or errors and the sound worked fine and calls worked fine. The previous installer used only twisted ends and electrical tape to secure the wiring so I took the wiring apart and used wire nuts to make sure nothing came apart while it was being installed and for longevity. After starting the car back up, I received a brake proportioning fault and an oil pressure fault and it told me workshop fault as well. I pulled fuse 40 as I heard it resets the system and plugged it back in. The brake proportioning fault is gone but the oil pressure fault remains. I double checked my wiring work to make sure that I was not missing anything and nothing had come back apart. Everything is indeed attached and plugged in. Now that I have finished my long-winded story, was this fault caused because I knocked something loose or because I left the fiber optic cabling unplugged for too long. I noticed that there was a red light coming from the input and of the fiber optic cabling a couple of times while I was rewiring it. Do I just need to reset this system using a better method or do you think something is wrong with it? Any help would be appreciated and I intend on donating to this forum and website as it seems to be a true source of knowledge and help for the DIY Porsche enthusiast. Thank you in advance and I look forward to your responses.
  2. I have a 1999 Porsche Carrera the oil pressure when the car is very hot drop in less than 1 Is it normal? Note: I live in a very hot country
  3. 2002 911 C4S Six speed manual When driving my recent purchase, the oil pressure gauge reads "5" whenever the tach goes 2500 rpm or above in any gear. This is when it is still warming up or at operating temperature (180), after at least 30 minutes on the road. Needless to say, I've been keeping the car below 2500 as much as I can. At idle, it registers between 2-3 after reaching operating temps. Last week, I had the Porsche shop remove the oil pan and check it for any detritus during the PPI. It was clean. Then they proceeded to put on a new filter and oil. I've checked the oil level in the morning, and it registers a smidgen over max, however, the computer level always registers a 1 bar over max, whether hot or cold. Would a faulty oil level sensor affect the oil pressure reading? I've read the oil pressure sensor can be wonky. I don't have enough miles in this car to really know it yet. It's, obviously, a bit frustrating to keep this car in check while driving right now, but I'd rather cautious. The owner's manual I have says the oil pressure should be approximately 3-4 bars at 5000rpm at operating temperature. Any thoughts? Or direction to go?
  4. I did an oil change on my 2004 996 Carrera using the correct amount of Porsche specified oil about 1,500 miles ago. Now after running and car and letting the oil settle back to the oil pan the dash computer level and dipstick are reading the same. The oil level is half way from the min/max levels. I know that the oil level is in the acceptable range now, but is considered having low oil? The reason why I am asking is because I brought my car to get diagnosed (and fixed) for a faulty oil pressure sending unit problem that occurs rarely when the dash warning pops up saying oil failure and the oil pressure gauge goes to 0. Then when I shut off the car the error disappears. I think it has to be the oil pressure sending unit, especially from other similar issues on this forum. Some history on my car. Well I bought the car from carmax and purchased the maxcare warranty. I was going to put the part and do it myself but it was too easy and I said let me use the warranty (since they would use Porsche parts) and I won't have to buy the part. So when I bring it in they tell me that if they can't find a fault they have to charge me a diagnostic fee. I said ok I know what the problem is and the oil pressure sending unit is covered under the warranty so go ahead. The call me back with the results and told me that their Alltel computer diagnostic system did not read any faults and the first thing they did was check the oil level and it was low. I was upset because I run the oil check every time I run the car and I never received a low oil light on. I ran over there because I thought the technician doesn't know how to read Porsche oil and we confirmed that the oil level was smack in the middle of the min and max lines and no light on the dash. My response was oil level is good. His response was that oil level is low and that could be the cause of the oil pressure sending unit. My first question is that oil level considered have oil that is too low? I need help because I feel Carmax just conned me out of a diagnostic fee because they didn't even proceed to look for a loose wire or anything. They said if the oil level is low thats the first thing that needs to be fixed. I would understand if the oil level is low. But it is in the middle of the dipstick in the acceptable range? Please let me know if my logic or theirs is wrong. Thanks.
  5. Hello, I have some worries about my Porsche 994 C4. I have had the engine replaced last year because of a cracked cylinder, since then the car has been a pleasure to drive. I recently noticed the oil pressure, when fully warmed up fully, has been dropping to about .2 - .3 BAR. The car makes no strange noises, and the warning light never comes on. After a recent oil change at the dealership, I was told there was nothing to worry about, but I think that there still is. I read it is never supposed to be that low. I changed the pressure relief spring, nothing changed. I changed the pressure sender, nothing changed. I'm very stuck on what to do. Tomorrow I will hopefully check with a mechanical gauge. I was hoping someone could shed some light on this for me. Maybe if anyone has encountered similar problems. I'm worried it is something bad. Could it be a bad gauge perhaps? I'm curious how the pressure can drop so low, with no warning light. Any suggestions would really help, this car has been quite the handful so far.
  6. I have a 1999 996 Carrera 4. Oil pressure reads 5plus all the time the engine is running. No idiot lights. I want to diagnose the problem myself. I want to fix it myself if I can. I suppose to start I should check and see if the sending unit has wires attached. Where would I find the sending unit on the engine block. Under the car, drivers side, centerline? etc. If they are attached my next thing is to check actual pressure. Could it be that high? Obstruction somewhere? Oil is not overfilled and is fresh. Can any local shop check the pressure? Where do I get a new sensor, best quality and price if it is just a sensor? I would think if it were a bad sensor it wouldn;t read anything. Ask me about lungs. I can tell you all about that. No really. Here, well, I'm a novice wanting to learn. Frank
